1964 Windshield Question
Boise, Idaho
I just bought a 1964 windshield and just noticed that it does not have the little hooks to clip my hood hooks onto When I fold the windshield down on the hood.
My other early windshield has the little hooks on the windshield. Does anyone know anything about these windshield frames?
thanks guys...
FJ45 LV ?
It is off a 1964 FJ40. I’m confused as my other early windshield has the little hooks. If the windshield folds down something has to keep it in place...
Could be a windshield from a hard top model. I am not certain but they may not have the catches like the soft top windshield. The catches on my FST windshield look to be a small bent piece of metal, fairly simple to make if you have access to some metal working equipment and a welder.
Where did you mount the catches? can you post some pics?
The early FHT models also did not have anything on the hood to hold the windshield down or pads to rest on. Have a couple of early holds for from FHT 40s that are like the FJ45LV hoods. Some early 45LPs the windshield was part of the cowl and other had a plate and not a hinge holding the windshield on.
Thanks... i Guess I need to figure something out..
John, I see where you’re coming from. But if it was an FHT windshield frame, would it still have the inside hook for the dash mounted latch?
It does seem that the inside hook and no loops on the top are inconsistent. But the corresponding lack of threaded holes for an FST channel are also consistent with the FHT theory.
:meh:
:meh:
I've seen never the 45 cowl that the windshield was part of the cowl only diagrams. Those possibly before Toyota imported the 45. The same with the plates instead of a hinge. Think some poste about having those on Mud. Again only on the 45 pickup in the early fixed top. These were early before the hook and latch. Instead used two brackets with a stud on top going down thru a groove in the bottom bracket. A nut secured the the two together. The FJ40 shared the same two brackets and have a hinge. Still have what is left of early 61 FJ40 FHT. Believe it was some time in 1963 the hook and latch started. Pretty sure it was until later the threaded holes for the soft top channel at the top started and the FDT channel was no longer spot welded to the windshield. Not sure when Toyota made the 40 more universal where the tub had both threaded holes for the hard top sides and holes for the FST twists along the top. Wasn't it Destin who had the 64 FST that the defrost ducts had to be removed before the windshield cod be folded down. Toyota added defrost vents during 1962. Optional factory install heater some time during 1964. Wasn't until the vent from the windshield was replaced by the one in the cowl was it possible to fold the windshield down without removing the defrost ducts. During the first half of the sixties did a number of things that didn't make sense. Just having hinges on the FHT and no pads on the hood didn't make sense but that is what they did. Welded on a loop to hold down the windshield only on models with windshields with the spot welded channel makes more sense than many other things. Will be at least a week before I am able to look at the three early FHT windshields I have. Doubt any have the loops but all three are either 61s or early 62 before the hook/latch. Would make sense when unversal threaded hooks replaced spot welded channel all had the welded loops. But obvious Toyota didn't always make sense.
Great information... like I said originally, I have two early frames, one is a fst and it has vent in the frame and the fst track welded on the frame. It also has the little hoops for the hood hold downs....
can you post photos of your frames?
thank you
Looks to me like a Fj45 fixed top short bed windshield frame given the 2 bolt mirror arm and lack of the nutserts for the roof latches across the inside top above the visor holes. I have both 45 fixed top windshield frame and 45 removable top frames at the house. Did it come with the 2 latches to keep it upright installed when you got it or were those installed by you upon arrival?
Yes. It has the latches that attach to the dash.
Did YOU install them or did it come with them? a fixed to 45 windshield frame has the same 2 bolt holes but a different way to keep the windshield upright.
My early’65 FJ40 FHT has the elephant horn windshield clamps but no hood pads, clamps or windshield hooks to hold windshield down if/when folded. It also has the defrost brackets that need to be removed before the windshield can be folded.
My 64.
defrost ducts and no hooks. When I first realized it, it left me scratching my head...
