Build 1964 FJ40 Build
Fman said:
It might be something to consider to go with at least front wheel disc brakes, seeing as you are running 35" tires. At least do it for safety reasons. Looks like you are doing a nice job on your build up, cant wait to see it done.
35" tires with drum brakes = :crybaby: :doh:
Fman
I have decided to go disc brakes on the front with later model front axle,and hopefully longfields and a locker, eventually. It's probably the smart thing to do. But as of now I just want to get her started.
Thanks for the advice yall
-my64fj40
In this pic I'am mocking everything up for the new engine.
Then put the intake on.
I didn't like the way the Edelbrock intake was lookin with bare aluminum so I decided to give to a couple coats of high temp paint and a clear coat.
Then I went ahead and put my TQC in the tranny.
And dropped the engine in with it,,,
Put some new U-joints in the driveshafts, ended up making the rear one a little longer. And also put an AA kit on the front so I would have to modify the tranny drain pan, along with new ujoints...
Here is some pics of the body work I did...
I replaced:
1. Metal under the doors on both sides.
2. The rear sil including a new c - channel
3. The rounded c-clips on the rear of the cruiser.
4. A few little spots that I welded up.
Then I through everytthing on my flat bed and took it to sandblast and prime.
The place the did this for me was a powdercoat business and luckly they have a oven that the tub would fit in to. SO............
And while that was being done I took a vacation up the Dallas..
Where I stopped by Cool Cruisers and picked up a bumper...
I wanted to mount it with 1/2 grade 8 bolts so I had to drill out the chassis and bumper plates a little bit...
The cool thing about this epoxy powdercoat primer is that since it is applied in a powder form that electrical charge can suck that powder up into every little crevice and such...
Can't wait to get the rest of the cruiser back
Anyone know where I can find a Good well known distributor for a decent price for my 400 SBC. The engine builder told me it needs to have a vaccum advance.
Went by some local shops looking for one, couldn't find any, but ended up buying these to replace the stock reflectors..
AlaskanWheeler said:
How is the the qualtiy of the sheet metal from real steel cruiser parts?
It was good quality metal, everything seemed to fit just fine...
But then again I have never used CCOT or anybody else so I can't do a comparsion there..
