- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,507
Did you put the floor drain plug under the fuel tank from inside the cab? Or from under the cab? Might be easier to remove int he future from under the cab.
It’s one of Matt’s @ToyotaMatt repop plugs, they can be put in place from under the cab.
The Gas Tank drain plug rubber Grommet i offer is a Re-Purposed OEM Toyota Part .....
also , i Needs to be installed from Under the body , NOT from the top this way it;s removable in the future for service , from the top , you will never be able to remove .....
Sweet Progress Paul !
looking sharp
. But after reading 10k threads on valve cover seals, it finally dawned on my puny brain to take a look at those. And all 12 “umbrella” seals* were parked at the top of each shaft! Don’t know if they were up there from the git go, but the really bad smoking didn’t start until I fumbled through the bad timing, so I’m wondering if that bad timing added some extra umph in pushing the seals out of place. I’ve pushed the seals back down, and tomorrow I’ll fire it up and see how the smoke signal generator is working. Here’s one of the seals in its correct space - wonder if it will stay there? We’ll see.
. I replaced one when I rebuilt both carbs, as it was crushed. So I don’t know if this was the replacement one or the original one, lol. Two new coming from Mike’s carb parts.
