- Thread starter
- #221
*EDIT* after measurements
I think this is correct, by memory
3SGTE 1st gen. Round Port - CT26 (40mm or 43mm? Comp Inducer)
3SGTE 2nd gen. Split Port - CT26 (40mm or 43mm? Comp Inducer)
3SGTE 3rd gen. Round port - CT20B (slightly smaller turbine, 47mm? inducer)
1HDT Auto(manual?) Round Port - CT26 (43mm Comp Inducer, larger A/R Ex housing than 3SGTE)
1HDFT Auto(manual?) Round Port - CT26 (43mm Comp Inducer, larger A/R Ex housing than 1HDT)
1HDFTE (CT20B?) - only says "Toyota" on compressor cover which is typical of CT20B (so called)
7MGTE Round Port - CT26 (47mm Comp Inducer, largest A/R exhaust stamped 42010)
Currently I have 2 x 12HT exh housings (stamped 58010), 2 x Supra housings stamped 42010, 1 x 3SGTE twin entry stamped 74020. I cant remember what was stamped on my 1HDT - I will check a friends.
Some CT26 turbines fitted to the CT26 were ceramic, the one I used on my 1HDT was ceramic. It definately spooled like it had low intertia.... I was out to prove ceramic doent die because of boost - they die because of too high EGT's. I proved it too. 27psi no problem. Turbo was not efficient at 27psi however....
I have read many "statements" that the ceramic turbine flowed more or was bigger than the steel counterpart. They measured the same and looked the same dimensionally.... I only tried it for the reasons mentioned earlier and it worked fine. Ultimately though, the metal turbine is easier to modify - if indeed the/a modification is beneficial. I had a real problem with exhaust backpressure on my 1HDT due, I expect, to the small exhaust housing. It was able however to make terrific torque very early in the rev range, so as a driver/tow horse, it was really something special. After driving a 100 series auto, my 80 series really felt "strong" off the bottom end and to ~ 2400rpm. I have not got anywhere near that performace from my 12HT....yet. The key is low backpressure/boostpressure ratio for whatever boost you are making in my opinion - which is the reason for the twin idea (increase overall turbo efficiency).
