Dougal: I bought a vacuum VNT actuator a few days ago off eBay. Typical Audi/VW type.
I also bought a while back a dual port waste gate adaptor. That was how I intended to increase the boost with rpm - by feeding the high pressure side to the top and the low pressure side (between the two turbos) to the bottom. This would cause the boost to rise with rpm.
It turned out that the dual port was rubbish and while it has "two ports" the lower section was not sealed, thus would require me to machine up something to suit. No problem really, just a pain.
I am not sure how much the force required to close the vanes will change with rpm, this is an aspect that will require some tuning.
I complained to the seller and they gave me a complete refund on the dual port actuator on the basis it was not what I ordered. I really wanted the dual port option and still would be happy to find one. It is hard to tell actaul size from photos and I was a bit suprised how small the diaphram is! Anyway, I *may* machine up a seal that I would"Devcon" on. Just have to make sure that the air leakage rate is suffciiently low enough as to not impact on pressure in the diaphram without going to large diameter hose...
I am looking at the moment for cheap banjo fittings and the like, these are the types of things that put a slow down on my projects - just getting the right bits. I am not a thread expert and dont have any thread gauges (maybe I should by some, theres an idea) so I know that I am buying the right sizes.
Perhaps the twin turbo is alive after all.
Things to do to make it happen: Buy some TIG gas, buy oil/water fittings, machine up my 20G compressor wheel, machine up another clipped CT26 turbine, get balanced and take the compressor cover in to get machined to suit, make GT25 dump to CT26, make CT26 compressor to GT25 inlet section, make CT26 dump (I bought a new flange and will use expanded tube fittings to reduce turbulence - same for GT25 dump), find a way to to a bracket to hold it all nicely in place, make it. Set up VNT control of GT25, put boost controller on CT26, just in case it is needed and the easy part; install.
All sounds so simple!
I have seen dyno of stock CT26 up to 340rwhp and high flow compressor modded CT26 versions to 436rwhp. A TD06 20G did 460rwhp and this is what I would expect, since the exhaust turbines are very similar. Both at 20psi
Would it be reasonable to expect that 300rwhp might then be possible in the diesel with a 20G compressor wheel? I have been working off 1.3-1.4 Bar, which is where the efficiency is best on the 20G compressor wheel. No matter how many times I run the calcs, I keep coming back to it being a fairly good match. This is why I have persevered with the CT26
Seems the turbine in my small VNT is the same as the GT2860RS. Does that make it a GT28VNT then?
After a look through many of the turbos on the Garrett site, it seems the difference between a GT25 and a GT28 is the Turbine Trim. On that basis, mine is actually a GT28VNT and now that I think more about it, seems a great match for an automatic.
So, here is a project plan:
(1) Fit current GT28V and water to air intercooler, get VNT control working well.
(2) Upgrade compressor to Mitsubishi 19T, Small 16G or Disco Potato or ? Problem is shaft diameter is 5mm or 5.5mm (cant remember), very small. I would like 48-49mm inducer.
(3) Probably fit a 12HT to my 80 series at this stage
(4) Add second turbo
(5) Snap GT28V turbine shaft and or break conrod under heavy boost.........
#5 notwithstanding, this rational is a gradual approach that allows some learnings.
I havent actually measured the inducer of the turbine. I have only concerned myself with the size of the hole the ex must escape....
I have the housing off anyway at the moment, I shall measure it.
The exducer on my little VNT is identical to the exducer on the GT2860RS, thats why I thought it was probably a GT28....but I will get the vernier out!
The Mits 19T wheel has the same bore diameter, 47mm inducer (very similar to DP Compressor), I checked that a while ago. Problem is I dont want to go smaller on the exducer and the induicer is too small for the one turbo to satisfy my power appetite!
I think the intercooler will make a fine filter (no pun intended)
Hi Tapage, yes, many times have I measured the CT26 in variety of forms. Also I have many at home (4). The 1HDT has the same compressor wheel as the Toyota 3S-GTE found in MR2's and GT4 (Alltrac) Celica's. 1.575" inducer compared to 7M-GTE 1.75" Inducer. The Turbines are exactly the same, the exhaust housings are different. The 3S-GTE housing is a smaller AR, the 1HDT is next biggest and the 7M-GTE is bigger again. I have tried the Supra exhaust housing on the 1HDT, no good, much too big. Less than 3psi before 2000rpm.......
There is a bigger factory compressor wheel again (never actually seen one, but have owned) that is found in the CT20B. I understand the inducer is 1.85". I would like to buy one of those wheels.....
