VTcruiser: This thread is a free for all.
The turbo in the picture, it that from Maarten?
VTcruiser - looks like a Supra comp wheel, or at least from the same family. Definately not a T04e, so you are safe. Anyway, buying from Maarten would be a safe option.
Here's Maarten's reply to my email. Pardon the grammar, English is not his first language:
VTCruiser; is it possible you can you check with Maarten if the "change in housing for indrect vs direct to ~0.7" is a increase or decrease in AR?
The power figures I quoted earlier were all at flywheel, not at the wheels.
And how was the power of your setup and what boost pressure are you running - intercooled or not, decent exhaust? Any dyno report? I have seen a few 1HZ's making very serious power now (>200rwhp) with the Garrett GT series turbos. One such video was very impressive.
herehttp://www.melett.com/turbo-parts-catalogue/toyota/Toyota.pdf
Brilliant info.
While it is hard to measure accurately, I am sure of my measurements the onther night. I was told that some JDM 7MGTE CT26 had the biggest of the compressor wheels and both the Supra CT26's that I have are JDM and were like new condition. I since sold one and have kept one. As a result I am quite happy that I have the bigger 47mm wheel and will install it soon!
Interesting info all round. There are some variances depending on area that the vehciles were originally built for but all round terrific data.
For example, JDM Supras often (not all) got ceramic turbines, USA got steel. This was the case for the 2JZGTE also. the steel wheels for the USA were also bigger trim.... Makes it a bit hard to be conclusive.
.can you explain choke flow? and how would you tell if this is happening (apart from turbo desintegration .
I had chatted with a turbo rebuilder about ct26 and asked him what safe boost limit was. His opinion was that they are safe producing up to 22psi (I think he was talking about supra turbo), so I was happy enough to let mine peak at this pressure
My 1HD-t is mated to a manual.
re supercharger, the thing that appeals to me is bottom end torque from idle especially with a manual. As deisels are low revving compared to petrol, the supercharger could be significantly overdriven and stay within its efficient range. Sounds like this is what your bro did?
compounded with the a turbo providing secondary boost, as the supercharger is approaching the top end of its stand alone efficiency range, the turbo will be feeding a greater volume of air than the supercharger would draw on its own, and the turbo has already compressed it. My thoughts are this is going to change the superchargers characteristics quite a bit.
I have found several s/c + t/c compounded vehicles with guys' experience supporting this idea
I have thought about setting it up with a clutch, but think it would complicate tuning of the mechanical fuel pump, same with bypass. If it was clutched or bypassed at idle, I think it would be very smokey. I think to get it to work best, I would set up the aneroid so that it didnt see any boost signal from the supercharger, and pick up boost signal from the turbo.
one thing I'm not sure about is if the supercharger was overdriven, would this put an ecxessive load on the engine at low RPM? I think the deisel is probably torquey enough to cope.
gbentink and Dougal,
have either of you considered using a supercharger in compound with a turbo?
I have a Eaton m112 supercharger I am contemplating using on my 1HD-T with a large turbo for secondary boost.
I have read of guys having a lot of success with this on petrol V8s, beyond a lot of peoples expectations.
The supercharger provides boost from Idle and helps the turbo spool up quicker due to scavenging action and increased exhaust volume. Once the turbo is producing boost it increases the volume of air available for the supercharger to pump.
I know lots of people regard superchargers as a parasitic drain on the engine, but it seems to me that S/C and T/C would work beneficially with each other and give the best of both worlds.
just wondering if you guys have any thoughts on this without hijacking gbentink's thread too much![]()
Have you noticed that there are no factory supercharged diesels? Only turbocharged.
the need for boost in a diesel continually varies
Why is this so? I would guess cost and simplicity of manufacture would play a big part?
I am sure I read somewhere recently that one of the big car makers had developed a compounded s/c+t/c system for a small diesel passenger car? could be wrong.
I know Nissan built a car a decade or so back, using s/c+t/c. it was only available in Japan and was developed so it could be used for rallying
could you explain this? I would have thought having forced induction is always going to be a good thing?
It isn't just cost stopping them from supercharging. The economy and performance loss is a major too. Economy diesels are turbocharged, hot-rod diesels are turbocharged.
VW currently produce a twin charge engine (supercharged and turbocharged), but they're petrol. They overlap the supercharger and turbocharger to get a wide torque curve. Diesels don't have the same rev range and can take higher boost so it's not a problem.
I haven't heard of that Nissan, we get all the JDM cars imported here (New Zealand) used.
Since diesel engines speed is controlled by fuel, there's no point in pumping more air than is needed. It takes a lot of power to produce boost and doing so when not needed costs fuel economy among other negatives.
That's the best thing about a turbo. When the engine works harder the exhaust temps rise which drives the turbo harder and creates more boost.
So boost is balanced to the need for it (in a well matched system).
ITS A SLIGHT INCREASE AS THE 1HZ PRODUCES HOTTER EXHAUST GAS AND A BIT MORE VOLUME AS THE 1HD-T WICH HAS A LOWER COMPRESSION RATIO.
Hi Dougal. The twincharge engine being referred to is the 990cc engine used in the Nissan March. It was used for a while. They may still make it
