2005 Fully loaded KDSS, Tan interior, ML, Nav, rear entertainment, tow package. 101k miles, Sport edition.
GULFPORT, Ms.
$13,500 firm.
New dash recently installed by Lexus
At 100k miles
The FULL Timing belt job was completed (yes full, not just the timing belt. EVERYTHING that consist of doing the job correctly. Toyota parts)
Radiator was replaced at the same time. It wasn't leaking enough to notice. Coolant crud was built up on one of the tanks. Pressure test revealed leak. Never over heated. Toyota coolant was used along with Koyo aftermarket oem replacement radiator.
Plugs were replaced using NGK.
Driveline service was done utilizing Mobil 1 fluids
Front, Xnsfer, rear diff
At the same time both front CV's were replaced as the old ones had torn inner boots.
Metal Tech rear spring conversion kit used.
FJ springs and 4R shocks from Toyota.
New front 4R shocks as well.
Pocket installed in center console in place of the shock dampening controls.
Has new remote and head sets for the entertainment system and everything works.
Stepped up a size on the tires. General Grabber AT2s installed @ 88k. Routinely rotated and air pressure properly kept.
New spare tire installed as well(not GB AT2 and factory size)
New TPMS sensors installed at same time as all tires.
New Lexus floor mats at 88k as well.
Oil changed always using Mobil 1 5W30 and using Yota D3 filter.
New wipers front and rear from Toyota.
New Hood shocks from Lexus
Battery replaced 1 year ago.
Tinted windows 1 year ago.
Key fob replaced.
The bad.
Both front door speakers are blown. Could send them out to get refoamed cheaper than new speakers
There are 2 rock chips in the new windshield. Both repaired to prevent spider cracking.
The driver mirror has some chipping paint.(may have this repainted this week depending how busy I am)
The rear bumper was backed into.
The reflector has been replaced and it doesn't stick out anywhere near as bad as it use to, to me. (The only accident it's been in since we've owned it. Someone backed into it while it was in a parking lot and left no info behind)
Only have 1 key.
Other than that it has it's normal wear, tear, and rock chips that a vehicle with 100k would have on it.
It will be due for an oil change real soon in which I will have performed when it is due.
Everything functions as it should. No warning lights on the dash.
Still financed through Keesler Federal Credit Union
Will make a solid platform for anyone wanting to build it up and will be driving maintenance free for another 100k for the most part.
Your gain my loss. Sure it won't last long.
