Quick 2005 LX470 validation update:
Prototype #2 is now installed and communicating correctly on @LJE’s 2005 LX470.
Initial startup did uncover an OEM integration quirk that kept the controller sitting at the firmware banner instead of transitioning into the normal HVAC screen. We spent some time isolating the factory configuration and communication path, and after working through that, the controller came online
without any firmware changes, PCB changes, or pin swaps.
That is a pretty important result because this truck is:
- a different model year from the development vehicle,
- using a different factory A/C amplifier revision,
- being installed independently by someone outside the development work,
- and using the same controller hardware/firmware we have already been validating on the 2006.
Alex also caught a few small mechanical details in the faceplate fitment and OEM lower-button locating features that would have been easy to miss on a single development vehicle. Those are already being cleaned up in the next revision.
Not calling the 2005 fully validated yet. The next phase is deliberately boring: repeated ignition cycles, engine starts, HVAC ON/OFF states, temperature/fan/mode control, A/C, recirc, defrost, AUTO, dimming, shutdown/restart behavior, battery disconnect recovery, and actual road time.
But the big takeaway today is that the 2005 architecture is talking to the existing controller without needing a separate firmware branch so far.
Huge.. HUGE thanks to
@LJE for tearing into his own truck, checking diagrams, testing combinations, and being willing to work through the weird OEM behavior instead of just stopping at the first unexpected result.
'06 LX470 - Fully Validated
'05 LX470 - Partially Validated
One small caution from today’s troubleshooting: Avoid Luhzeng adapters if you can. (Looking at you Teyes/Chinese Android HU owners). On these trucks the factory audio/HVAC/network architecture is interconnected enough that adding another adapter can create a second unknown and make diagnosis much harder.
