100 Series General Tech and Classifieds
Does the OEM Jack still work on a lifted truck with 33's?
It will work for changing a tire if you put it under the axle housing.
No, but I keep it handy anyway.
...via IH8MUD app
It has still worked on every truck I have owned. 34s on 100 it works under lower arm and rear axle as intended and had 34s on 60 and it works under axles.. I have found that I put the high lift base under it in muddy and sandy situations very stable.
Def correct it will work under the axle. I've just gotten so used to the frame and sliders as lift points don't ever use the axles anymore. It's always in the truck, just in case.
...via IH8MUD app
Thanks for the info on the jack.
Fwiw we are down to 12.2 doing 75-80 across KS. Just passed into Colorado!
When are you and the southern crew getting to the party?
That's not a bad idea. We are eating at Fogo tomorrow night, might get a slab to take with us.
Have a full pan of jambalaya and 4 quarts of gumbo freezing right now for the potluck Friday night.
Thanks again to CLC for the ARB fridge/freezer :)
...via IH8MUD app
Rolling
...via IH8MUD app
