Appreciate the photos and commentary, I'm hoping to accomplish the same job after the holidays so it's helpful to see you working through it.
Appreciate it! Soon I’ll wrestle the beast back in.Good work @OhioFJ you are doing fine.![]()
Curious on how that parking break drum gets scored that bad. only the seal sleeve touches it, right? perhaps rocks or brake debris?
YAMAHA Outboard Marine engines and personal water craft use stainless steel JIS zerk / grease fittings , they are made in japan by the same exact OEM parts maker
ASCO Corporation as any non-stainless Toyota vehicles ones are still today in 2021 ....
- they have all the same exact profiles and thread pitches and diameters as Ari's FJ40 Propeller shafts , tie rod , relay rod , drag link , and center arms factory ZERK
locations etc.....
- TOYOTA does and has OWNED outright YAMAHA since JIS and JDM time began long ago .....
ill post up the various YAMAHA part numbers i use in my shop since my time began at age 16 ,
some long time ago too![]()
zerks corrode from the inside out in general , it would be good fit form and function step by step to simply replace them as a matter of Course due to age and time in
general , the spring and check ball are moving parts and subject to all the quams we are all too familiar with in general ....
do u plan on replacing your Spider Gears as a whole or re-installing the existing parts u pressed out ?
ill see if i have a replacement cap / cup / plug u detail above ...
they are basically a glorified freeze plug like on a engine block ,
