1 Gallon in diff?
Bozeman
Hey all,
I'm baselining my new LX and just swapped out my front diff oil. When I removed the fill bolt, some oil dripped out, a good sign. When I drained the oil, I got about 3.8 quarts of oil out. BTW, oil looked clean, no funk on bolt magnet. I refilled with about 2.8 quarts, which filled it, and the FSM says is capacity.
Where did the extra quart come from?
Prob knuckles leaking grease and vice versus aka birf soup
Or water
Knuckles clean on the outside....assume bad inner seals?
Don't assume anything. Drive it for awhile and check the level and clarity of the gear lube. If it stays a healthy green 9 or whatever color it was going in, you should be good for awhile.
That's my plan. It just seems weird to me that when I opened the fill bolt, couple of drops came out and then it drained 3.8Q but only 2.8 went in. If there were 3.8 in there somewhere, why didn't it pour our when I opened the fill? I'm stumped! :confused:
someone may have overfilled it sitting on a incline or something, quick lane jockey overfilled and just shoved the plug in. Or water.
It is easy to overfill them. You can get a lot of it to go up into the arms of the housing. Did you let it drain for a long time so all of THAT could run out?
Your scenario was the one I had considered most likely. Yes, I drained it until the dripping stopped, then the refill. I'll drive it a bit and recheck. And recheck. And......
I'm with inkpot. Likely someone filled the birfs with 90wt instead of moly...and the inner seals failed.
Old Land Rovers used gear oil instead of grease...maybe the Po was a old Land Rover guy.
John
