1/4 Panel patch with limited tools
Great write up! Thank you
awsome thread...........:clap:couple of questions.........have you done any floorboard fabbing?; what did you do to solve the bead fabbing?.......and what wire welder did you use?:beer::beer::beer:TIA
Lou
toyrod,
Thank you so much for this posting. I like the way you think....Cheap yet properly done. I was looking the other day at the cost of some of the patch panels that I need at CCOT and was thinking, I don't know if I could accomplish this without winning the lottery.
Couple questions:
What gauge metal? I don't know if I missed it in the reading.
Also, what kind of welding equipment are you using? I am thinking of purchasing a Hobart 140 or 187, but I am always interested in what others are using.
Couple questions:
16 gauge cold rolled steel for anything that is hand formed.
Also, what kind of welding equipment are you using? I am thinking of purchasing a Hobart 140 or 187, but I am always interested in what others are using.[/quote]
I'm using a Lincoln 185. If your just going to do sheetmetal, any namebrand 110V will do. Flux core wire will keep your costs down also.
Lou
I have only used diamond plate to replace floorboards. I haven't figured out a cheap way to duplicate the original ribs.
Not sure what you mean by "bead fabbing".
bead= the streangthening ribs on the floorboards; they are "rolled" when hand made or from factory are stamped into the sheetmetal :)
Lou
That is true, the process of beading, stamping, rolling and flanging of sheetmetal does make it much stronger, however diamond plate is "plate" rather than sheet meaning equal to or thicker than 11G (in most cases) and therefore is going to be plenty strong enough with out the ribbing...for the front floor. Now on a flat bed truck, you'd want to support it with ribbing underneath.
"get er done"
Respect for this thread, good job man!
-Stumbaugh
That’s the method I used but I used an 8” pipe and rolled it. I wish you did this thread 6 months ago I like the way you rolled yours.
Awesome job!
Chris
Yeah! Nice.........now on to the floorboards!
This is inspiring me to do it myself.....
