2F valve cover on F motor
I did it two weekends ago. 2F valve cover on an F out of a '70 in a '74 FJ40. You'll need the rubber gasket for the 2F valve cover Fits like a glove.
Also seach is a wonderful thing, but to make life easy, here is how to polish it: https://forum.ih8mud.com/showthread.php?t=94966
wow that clean I may need to invest some more time cleaning mine up. Where did you find the gasket? part #?
and I'm guessing your just gonna cap one of the oil fillers?
the one on the block I mean or the one one the valve cover?
I believe any 2F valvecover off a 40 will work...
there was some point where 2F valvetrains and hence the valvecovers got shorter, and these will not work with an F. Not sure when that change was.
other than a gasket and potentially a different oil filler cap you are good to go. New grommets and nuts would be a nice touch.
jrfj40 said:
Are there any other parts I'll need?
Just the gasket and the 2F acorn nuts and rubber washers. There is a difference between the F acorn nuts and the 2F acorn nuts (which go down through the washer.
I don't have a part number for either, but then again I just picked mine up from Mark directly.
I just put a 2F cover on an F engine. I had to make one mod at the breather plate inside the cover where it made contact with the rear rocker arm support bolt. The bolt head was hitting the inter baffle. A one inch piece had to be cut out to allow the bolt to clear. Didn't polish it, nothing else on the truck is polished either...
As for the gasket, mine was 11213-61010.
Worked great, and should prevent the normal oil leaks with the old cover.
Jerry D.
I just found out that if you put both flat washers and lock washers on the 14mm bolts (the big headed ones holding down the rocker arm assembly) you can have interference with the valve cover. I just used the lockwashers.
My problem started after I decided to "upgrade" the valve train mounting hardware - it had worked fine before that.
Rocky
Where can one get a 2F valve cover? I'm interested in doing the same.
You will want a 07/80 and earlier cover, as the 08/80 and later covers are shorter and will not work on the F engine...
Post something up in the wanted section.
Good luck!
-Steve
its pretty easy, you'll need a new filler cap and gasket, well i need to replace the filler cap because the 2F cover has a push in one and the F is a screw in, other than that it'll on fine...no problems with the acorn nuts on mine...
