Build Project Toy-Audi
BiffS
Too many projects... ooh, look. Something shiny.
Vancouver, B.C>
Website
www.mekanix.ca
** Disclaimer** this entire project is intended to be something quite different. I've already heard enough of the "just put in a SBC" and things like that, so it's already been covered: not going to happen.
History:
This is a 1980 FJ 40 Landcruiser that was equipped with a 2F motor. That motor has been sold to a buyer in Louisiana, and is happily sitting under a 74 -FJ 40.
All the original engine related items have been removed and are long gone now. That an the 750 pounds of cast iron wonder. I've been suffering with the carb since I've had this truck and decided that fuel injection is the way to go. No TBI, No TPI, no GM anything.
I've had many VWs and Audis, thus: Project ToyAudi has been born.
Stats: 2.8L Narrow angle V6: 184 BHP @ 4200 RPM. Torque 215 LBS @ 3300 RPM, 400 pound engine complete, Fully fuel injected with a MAF setup, 3 ignition coils and a low clearance oil sump. This motor is intended to get jostled around.
Vehicle: 80 FJ 40 with 4 link front and rear, Fox 18" airshox, HADL driveshafts cut n turned front axle and 1 ton steering gear. Engine will be mated up to the factory 4 speed and T case. (edit: ended up using a V6 5 speed, 4cyl toy doubler and 4speed LC tcase)
Interesting notes: As well as being 350 pounds lighter than the 2F, it's even 14" shorter in length, and 4 inches lower in height. All in all, I figure that I can keep the engine weight down low and more towards the center of the truck.
Progress will be slow and methodical, so please bear with me.
Before:
2F on the way out.
4 rings. . .
Test fit in the bay. note how far back the motor sits with regards to the shock towers.
Side view.
The factory 4 speed bell housing has a machined flat surface on it . It looks like i can get some new holes punched in that will line up with the Audi block.
I'm already running a Jaz pro-sport fuel cell in the back behind the axle.
Donor vehicle was a 1996 A6 Quattro automatic. i can shunt the neutral start circuit and it won't be a problem.
Luckily Canadian motors don't have the additional emissions stuff that US versions do.
Keep in mind of all the OBDII parts that need to be addressed like both O2 sensors, pressurized fuel system with vapor purging, etc. Sounds like a cool project. Can't wait to hear the outcome.
Gary
biffs,
That sure looks like a 12v motor to me I worked for auid for 6 years in the usa and the thirty valve motors (starting motor code AHA) don't look like that. In us trim i think they were 167 hp and then 190lb ft of torque. You should really be hunting for a 300hp 4.2l all aluminum v8 from the A8 now that is a kickin motor and would make that 40 stomp!
good luck check out www.034motorsports.com they make VAG stand alone engine management stuff cool guys with some insanely fast 5 cyl audis :)
I'm located ub by UBC area.
THe engine i believe is an ACK code.
for the AFC engine, the details are as follows for USA version.
[SIZE=+0][SIZE=-1]
  • 2.8L / 169in3 / 2771cm3 displacement
  • Maximum output: 174bhp DIN (128kW) @ 5500rpm
  • Maximum torque: 250Nm (184ft. lbs.) @ 3000rpm
  • Maximum engine speed: 6700rpm
  • Bore: 3.25in / 82.5mm
  • Stroke: 3.40in / 86.4mm
  • Compression ratio: 10.3:1
  • Accurate fuel metering by means of a heated-wire
    air mass sensor
  • Dual stage multi-path intake manifold
    • Short intake path: 380mm
    • Long intake path: 780mm
  • Engine code: AAH, AFC
  • Weight: 355lbs / 161kg
  • Length: 17in / 432mm
[/SIZE][/SIZE]
Note the weight. That's my major selling point as wellas the fuel injection. I'm also interested in how the torque peaks out at around 3000ish RPM.
I had a 30 valve A4 for a while, and that inspired the selection of this type of engine. I'd love to have gone 30 valve, but i doubt that i could afford one and i would HATE to try to figure out how the drive-by-wire system works.
Anyone got a link for an 8A0 Wiring harness? I've got both Ho2 sensors and the manifolds. I might even run the cats to keep the gassy smell down.
More engine details at www.12v.org
That is certainly a different swap!
Just wanted to give you some weight references and power outputs:
I have a 3.8i (231ci) Buick Grand National turbo/intercooled motor that would make about 350ft/lbs tq at 3K RPM stock and 300hp all the way to its low 5400rpm redline. It weighs 420lbs fully dressed with all accessories, parts are relatively cheap on it and having a chip burned for it is only $75 for perfect tuning on whatever gas you have available. With lightweight starter ($90 new) and no a/c it would be be around 380lbs.
An LS1 all aluminum 346ci V8 weighs 480lbs with all accessories and will make 350ft/lbs tq at 2K RPM and pull to 6500rpm+ and make 400hp+ at 5000rpm+.
I hope that engine will have enuf power for the trails. I'm sure with enuf gearing you can do what you want.
Useful info to note.
I was trying to keep it normally aspirated, and most importantly fuel efficient as well as injected. The comparisons that i've made are relative to the 2F which came out, so i'm basing my reasoning on that. Plus i'm just a bit bent, so i thought i'd try something different.
original 2F made something like 150 Hp and 170 FT lbs or something like that. I might consider a mild cam or chip to get more out of it if i feel the need, but i think this will be suitable power upgrade over a carbed 2F. I'm also doing away with the power robbing emissions crapola, as this will pass testing with straight pipes, let alone emission equipment.
Progress report:
Didn't get much time over the weekend (helping a friend move) so i've only been able to look at the wiring mostly. The 2F flywheel is about 2 inches larger in diameter than the Audi version. I think i might need to look for a manual transmission flywheel and bell housing as a starting point for mating the two up.
One other discovery is that it will sit too far back in the engine bay if i mate it directly to the LC bell housing, so an adapter plate and stand off from the crank might be a good idea.
I'll post more pics and info this week.
sure you've got 35 more FT lbs of torque, but look where it is in the rev range. the 2f rocks my world because it'll drag a cruiser along at 300 rpm BUT i like your out of the box train of thought, i wish you well with it
I want to follow this, very interesting, and very "out of the box" Something I certainly would not do, but its cooler than the usual chevy V8.
Yeah, the low RPM grunt of the 2F can't be matched, that's for sure. In fact, some V8 guys say that a 2F will out soldier a V8 at the low, low RPM. The V of this motor will definitely provide some good low end, as well as provide some useable top too.
It looks like i might have to take a walk on the dark side: This motor is SO short that it will sit extremely far back under the cowl if I don't make some changes. I guess i'll need to think about a SM 465 or 420 or something. . . Dang. . .
check out how low this engine is slung in the bay. there's probably about 10+ inches between the top of the motor and the hood. There's also about 20 inched from the back of where the rad would be as well. The motor is also EXTREMELY low slung in the bay, it looks like i'll have to move my upper contorl arms to make it all fit in.
Not sure where the SM420/465 will help, shifter tower is in a similar location to the toy trannies. (If understand you need to move the engine forward some and keep the shifter far enough back so that it is out of the heater...)
Not to discourage you though, as it seems you will definatly need more gearing than you have already with that engine...
More power to ya:cheers:
good point. Anyone try doubling the 465 or 420? i have room to spare. . .
Advent said:
Thought about adapting a Ranger under/overdrive? That'd move it forward a bit.
No, I've never heard of that one. Got details? Right now i'm researching dual T cases or dual trannies. . . Can't seem to find any dual H 42s out there. THe Toybox is far too spendie for my budget.
