Drawer System - No Sliders...Bee's Wax
Mt. Pleasant, SC
I put this drawer system together today and thought you guys might appreciate a gander.
I used Jim Brantley's 60 series drawer system as a starting point since I also own a 62 and wanted to be able to switch between my 2 Cruisers. The 80 series is two inches wider so you can widen everything if you want it specifically for an 80.
I decided I did not want to use drawer sliders so I tweaked his measurements so a drawer would fit in there snugly.
I then thought it would be neat to have a folding bed extension that could fold over on top of the folded seat in the 80(just the first fold to bring the seatback down). So I heightened the drawer so it was level with the tops of the folded seats. As you can see from the pictures, I have not installed it yet. But I have the piece cut and I'll pick up some hinges tomorrow.
I took out the cargo tie-downs, but put the screws back in to keep everything dry from the undercarriage.
I used Gorilla Glue as well as screws to ensure a tight attachment.
I cut 2 openings in the case back and kept the drawer back short so you can get to stuff in the back of the drawer when it's closed.
The bee's wax is rubbed on top of the case bottom and under the drawer bottom. Slides VERY well.
I sanded all the edges and surfaces to smooth everything out.
I had Lowes cut all the pieces...and yes there were some very slight measurement mistakes.:mad: Nothing the sander couldn't fix.
I plan on either covering it with marine carpeting or painting it. Leaning towards the marine carpet.
Materials:
3 96" x 48" pieces 3/4" Plywood(I used Lowes #23/32" 4X8 BC PINE ULX EXTERIOR Item#:12229)
Box of Drywall Screws 6x1-5/8(countersinking)
Gorilla Glue
Bar of Bee's Wax
2 Hinges (I used West Marine's Stainless Butt Hinges Model 7219546)
6 Machine Screws "Round Combo w/ Nuts-Zinc 1/4-20 x 1'(Maybe 4 more if you use them to attach hinge to case)
6 Locking Nuts(Instead of nuts that came w/ machine screws; Maybe 4 more if you use them to attach hinge to case)
6 Washers(Maybe 4 more if you use them to attach hinge to case)
Measurements(inches):
Plywood panel #1:
A)Case Bottom 41.75 x 39.50
B)Case Top 41.75 x 39.50
C)Case Back 40.25 x 12.125
Plywood Panel #2:
D)Bed Extension 41.75 x 27.50
E)Drawer Front 40 x 12
F)Drawer Back 40 x 2.8125
G)Case Side 39.50 x 12.125
H)Case Side 39.50 x 12.125
I)Drawer Side 37.25 x 11.125
J)Drawer Side 37.25 x 11.125
Plywood Panel #3:
K)Drawer Bottom 40 x 38
*Remember. These width measurements are for a 60 Series. If you want it specifically for an 80 Series, the width is 2" wider. Just add 2" to blue measurements.*
*The measurements in red are FIRM. These are the measurements that ensure that the bed extension sits level on the folded seats. Also remember that I have removed the tie-downs and returned just the screws for a little more height and stability. If you decide to take the tie-down screws out or leave the tie-downs in, recalculate your height measurements.*
Now, that it's all complete, it looks like I could've lengthened the drawer by 1.75" which would position the back of the drawer right up to the back of the rear seats and the front of the drawer flat against the tailgate. But with this set up, I'd watch your fingers when closing the tailgate 'cause they'll get smashed if you're not careful.
The two symmetric holes in the rear of the drawer to access it while closed are each 10" x 5" and the top of the drawer back is flush with the bottom of the two openings. Measurements for the holes: 6.75" from each side of the case back(C) and 3.5625" from the top and bottom of the case back(C).
The two symmetric "handle" holes in the front were just cut out of convenience AND to get rid of two bigs knots in the wood.
Tools:
Drill
Jig Saw
Sander
Long Level/Ruler
Pencil
Beer & Sunscreen
Total Cost: About $90:flipoff2:
Finished the bed extension today. I plan on replacing the wood panel b/c the one I used was a wee bit warped and cracked. But is is functional and carries my weight fine.
Got the hinge from West Marine. "Stainless Butt Hinge Model 7219546"...but you can use any hinge of your choice.
I attached the hinge to the case with the original drywall screws. I might replace with the following...
I attached the hinge to the bed extension with Machine Screws from Lowes. "Round Combo w/ Nuts-Zinc 1/4-20 x 1."
I didn't use the nuts that came with the above and used locking nuts instead so they wouldn't vibrate off.
I also used washers.
I was so tired last night when I posted this. I guess it could've gone in Camping-Gear-Recovery, but I installed it in the 80 and it's really pretty specific to the 80 because of the height of the 80's folding seats. Meh.
I like the bed extension. Can you tell us the total length you were able to get out of it? I'm still planning a box for mine. Thanks!
Right now, the case length is 39.50" and the bed extension is 27.50" for a total length of 67".
I posted up my measurements and, as I said above, it looks like I could've lengthened the case by 2". But by doing this, you'd have to shorten the bed extension so it clears the ceiling when folding it over. I'd say that, given how high the case HAS to be to sit level with the folded seats, the total length will average 67" no matter how you try to reconfigure the measurements. Algebra can't be fooled.
Any concern with dirt contaminating the bee's wax lubricant?
I dunno. The old guy over at Ace hardware recommended it. Said it was "an old carpenter's trick for sticking drawers." Maybe someone with more carpentry skills can comment.
My own opinion is that dirt won't contaminate enough to affect it's sliding capabilities. It's hardened wax you rub on and I can't imagine enough dirt infiltrating the wax enough to stop it from sliding. I guess time will tell and I'll post up some updates.
...And it only takes a few minutes to rub on more bee's wax. I think the next time I rub bee's wax on, I'm gonna use a blow dryer to heat the surface to get a more even spread.
What are you going to do this summer when it gets hot enough to melt the wax in your car and it runs all over the place?
That is similar to my drawer design. I didn't add a bottom to mine so the drawer just slides on the carpet. I added similar carpet to the top and mine is the same height as the tailgate. I also don't have the flipover for a bed. One thing I found is that the drawer will slide until it is up against the backs of the seats (when the seats are in seat configuration). When that happens it will wear a line in your seats and it will squeak annoyingly. I cut a spacer that fits on the floor that locates the drawer. The spacer fits between the drawer and the seat mounts so the drawer system can't float too far forward.
Anyway, looks good.
There's not enough wax to do that. It's only an extremely thin layer. You can't even see there's wax on there. Just a very very thin coat.
A piano hinge would work even better and look cleaner.
Hmmmm. You may be on to something.
The only reason I spread the hinges out like I did was to have a completely flush surface to sleep on.
The piano hinge would produce a tiny gap b/w the case and the extension I think.
In fact, not that much. I used piano hinges and then carpeted the whole stuff, you don't feel any difference through the mattress:
https://forum.ih8mud.com/showthread.php?t=103792
Looking good. The front of your drawer is even more overkill than mine as far as screws go:D . Piano hinge wont leave a gap but depending on where you mount it, it usually sits a little higher than the wood itself.
If you merely wanted more support in the center you could use additional hinges mounted with flat head hardware. If your seats wouldn't hit it, you could accomplish the same effect by mounting a strip of wood, etc. along the front edge (down from the top edge equal to the thickness of your plywood) to support the extension when in the forward position.
Keep up the good work and here's a pic of my drawers:cheers:
...The front of your drawer is even more overkill than mine as far as screws go:D . ...
:o Like I said, I have no carpentry skills. I knew that the drawer front would get the most strain being pushed and pulled so I wanted to be sure it was secure.
I think I'm gonna give the piano hinge a shot.
