dual turn signal lense colors?
Tucson
I've been in contact with a few companies that manufacture injection molded lenses.
I'm trying to dig up some specifics:
1) I understand that the front lense was a different
color than the back one, the only one that I
have to go off of is one of my rear ones (the
deeper of the two) which is badly faded but it
appears to have been red maybe?
2) are the colors of the lenses the same as any
others located on the vehicle(s)?
Just to be clear, the lense in question is the dual lense front turn signal located on the fender
Amber front red back if that helps. The back one I have is red. I would be interested in a set of rear tail lights if you do these also. I will be up north this weekend and will try to find my set of turn signals. I think the one I have is in better shape. Of course I haven't seen the ones on your since the first of the year. But I remember thinking they were not good enough for repro.:cheers:
John
the one I have is a little rough
several cracks, and the outer edge is a bit beat-up
I'm going to contact KOITO's USA distributor located in Florida about these also. Figured it couldn't hurt.
the rear one I have here is got some possible model #'s on it. L 1046 ?
wonder if the front one is L 1045/7 ?
Are the one SOR sells not very close to OEM's?
The rear tail light lenses that Mike has are from the same source that SOR's are coming from. A front bib lense was used, not a tail light lense. They are close but not the same.
I will check this weekend for my turn signals. The lense is not crack and would probably be better for a repro. But it's up to you.
John
John
that sounds great John, thanks
Not sure if these are stock or not. Came on my '62 FJ40.
Never seen them adapted with the original base like that. Usually they drill a big hole in the apron and mount them there.........or take a hammer to the fender to make them stand up straight. :)
Hard to tell, but it looks like a small one :meh:
...if no one has some to spare, I'll get new ones :steer:
I may have stuck my foot in my mouth on that one Dean, as it appears they changed tail lights in '64 and that looks to be the one you need :doh:
but I am confident that isn't the correct front turn signal:grinpimp:
