I've been wanting to remake my custom air filter box and pipework to the turbo for a while now. The existing system works well and the dyno results prove that. But there is always room for improvement and, along with streamlining the intake design, running a different filter setup and eventually a 4in snorkel, I really like making stuff for the Money Pit, I mean Land Cruiser :mrgreen:
The turbo is mounted down low and the thermostat housing being quite close means there isn't a lot of room down there.
http://www.servimg.com/image_preview.php?i=733&u=14684539
This is the existing intake pipe I made ages ago. It's made from 3in exhaust pipe with a 4in flared end (foreground) that mounts up to the turbo with a silicone hose and clamps. The far end mounts to the air box with a 3in silicone hose and clamps. It does the job but we all know airflow likes the path of least resistance and definitely not 180deg bends.
http://www.servimg.com/image_preview.php?i=735&u=14684539
I had hoped a 90deg mandrel bend would make life easy but I was kidding myself...
http://www.servimg.com/image_preview.php?i=734&u=14684539
So the next step was to grab some 100mm exhaust pipe and starting bending it 'the fun' way, or as those in trade call it, lobster backing.
http://www.servimg.com/image_preview.php?i=737&u=14684539
Lobster backing involves cutting straight tube at specific angles to achieve the required bend radius. You can use an angle grinder but it's much easier and neater with a cut off wheel as shown. I knew I needed a tight radius due to the limited space but I wasn't exactly sure what angle would be ideal. With a bit of a guesstimate, I decided to set the saw backstop at 12deg and cut several sections, keeping the short points pretty slim. I tidied the burrs up with a flap disc on the 5in grinder.
http://www.servimg.com/image_preview.php?i=736&u=14684539
This is the bend tacked together. The bottom left section is a parallel cut for the silicone hose to be clamped to and fastened to the turbo intake. I tacked the next 2 sections on before testing fitting in situ. From there, I placed and marked each section in the desired location before removing and tacking into position. It's literally like stacking blocks on top of each other forming the shape you need.
http://www.servimg.com/image_preview.php?i=738&u=14684539
The great thing about Lobster Backing is you can twist and turn the bends any which way you need.
http://www.servimg.com/image_preview.php?i=739&u=14684539
Looking inside you can see there is next to no compromise in flow. Of course, that changes if you use larger sections to shape your bends.
http://www.servimg.com/image_preview.php?i=740&u=14684539
The nest step was to weld it all together. I used the mig and stitched it together in sections, letting it cool every so often before continuing welding. This really isn't a job for a stick welder unless you're very game or skilled. It looks like crap now but I'll hit it with the flap disc tomorrow and she'll look a million bucks.
http://www.servimg.com/image_preview.php?i=741&u=14684539
Nice work! I like the custom look of the stainless pipe.
