Anyone who said this was a dirty job was wrong, it is a *&%&@#!! filthy job. The bazillion photos of birf soup we've all seen just don't hit home until it is pouring out on your own shoes. Took me about an hour to carefully get the rig in the air and supported with four 12 ton double locking jack stands and chocks before I took the wheels off and about four more hours to get one side apart. Most of that was cleaning and studying the parts as they came off. A few things were hard to remove, until I got out my BFH and 30 inch pry bar. The top trunnion/bearing cap was really stuck, no where near as easy to remove as in the DVD.
Here are a few things I ran into:
I can't get the grease seal out from the rear of the hub. It is an aftermarket piece made in Mexico someone put in previously. Tried using my Sears seal puller hook thingy a dozen times, no go. Any suggestions?
Found the usual groove on the long axle shaft where the seal rides; how bad is this and does the Marlin HD seal help seal axle shafts with a groove?
The spindle has some scuffing, is it good enough to put back in?
Photos of damaged trunnion bearings and races
(First photos show how I placed the jack stands and chocks)
