Been awhile since I've been here, started my own business a couple a years ago and got no time. My LX450 has been using coolant at an alarming rate (2 quarts every 300 miles or so) and I cannot get a handle on it. Here's what I know.
170,000 miles on vehicle.
No evidence of coolant in the crankcase after 1500 miles.
Small amount of unidentified substance in coolant recovery tank.
Initial startup pressure in cooling system rises to 14 PSI rapidly, then tapers off and maintains for 20-30 minutes, then falls to 7 PSI and maintains.
Spark plugs were removed and inspected for deposits, no problem found.
No overheating condition, not at idle, not around town, not on highway.
No visible leaks, although there seems to be a small amount of wetness at timing cover below water pump.
No contamination in transmission fluid.
Vehicle idles and runs excellent, no hard or pending OBD codes present.
Coolant was checked for acidity+nitirites no problem found.
No anti-freeze smell or excessive vapor from exhaust, even idling in garage for 40 minutes.
I am a capable tech and this being my wifes ride it's giving me fits. I really don't want to take the time to pull this motor down if I don't need to. Any help will be greatly appreciated.
