I'm at whits end. 1985 4Runner with late model plenum and throttle body.
First, no codes.
Symptom #1: As the engine starts to warm up and it gets to 150* vacuum drops, idle speed drops, engine starts to stall, engine continues to run smooth. As the engine continues to warm up, and gets to 180-185* it gets better, but vacuum is still low. Engine lights instantly when 30* outside in the morning.
Symptom #2: If I shut the engine down, run into the store, and come back to an engine that has cooled down to 150* the engine will light quickly, but will run extremely rough. It runs so bad I can't get the truck to move under it's own power until it smooths out.
Symptom #3: Even after the engine warms up it still has a "miss" at rpm under load that can best be described like I'm being buffeted by wind. Just little hesitations as I'm driving. The engine idles smooth, though vacuum can be a little low (12" @ 5000ft).
Assuming a temperature and EFI issue: I've replaced the EFI temperature sensor which did help a little, but not much. I replaced the cold start time switch, which really made a big difference in how the engine runs, but really didn't solve the two problems.
My fuel pressure regulator was 25 years old with 300+k so I went ahead and replaced that. Not much of a difference. Maybe a little in how the engine runs, but it had no effect on the problems.
Fuel pump was replaced about 3 months ago after it failed.
One other odd thing I notice. I have a meter on the Ox sensor (air/fuel). Normally at WOT it would show something on the gauge. Right now, it glows dark. I suspected possibily Ox sensor, but a swap proved it wasn't an issue.
I'm running out of options. The only other temperature option I can think of is the throttle body which has water lines running into it. Other than that I'm down to TPS or AFM. I have boneyard backups of both and I'm going to swap in the spare AFM tonight. I don't expect it to be the problem. I'll clean the TB when I pull it to replace the TPS, but won't happen for probably a week. I'm leaning toward the TPS, largely because of the lack of response from the Ox sensor at WOT.
Like I said, 150* seems to be the magic number. Ummm, thinking ... EGR?
Any thoughts?
First, no codes.
Any thoughts?
