- Joined
- Jul 2, 2003
- Threads
- 132
- Messages
- 950
- Location
- Glen Waverley, Victoria, Australia
- Website
- jonathan-ferguson.au
I went to change my Fuel Filter last week, but I came across multiple problems, even though I had a genuine Toyota Filter ready to go and a new Filter housing.
The Fuel Filter is like a cylinder, as it is an integrated water separater, unlike what was fitted to the Car, which had a seperate water separater and a spin on fuel filter.
The other issue is that the mounting studs from the bracket are too big(diameter) at 10mm, but the new filter housing takes 8mm. Also, the new filter housing needs the studs 10mm further apart from each other.
The Toyota Filter mounted to the new Filter Housing just fine. To make 'em work I'll need a new bracket that mounts to the Firewall(Not available), and a new Water sensor which the local Toyota dealer said was available, but isn't. - I was even happy to pay the AU$190 + Tax they initially said it would be, and the 3-4 weeks to come from Japan.
I've been able to remove the Studs from the bracket and elongate the holes, so I can use 8mm bolts instead. But I need a Water Sensor, that mounts from the underside of the Filter.
Yesterday afternoon I got to see and hear matt.mcinnes' new Boat Anchor, and this morning he took Photographs of my Car.
