LinkBack (21) Thread Tools Display Modes
Old 01-31-07, 03:42 PM   17 links from elsewhere to this Post. Click to view. #1 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
2F + 3FE = 2F-ETI Into My FJ40
Well after reading a few threads on grafting a 3FE head on to a 2F block we have decided to go the whole 9 yards and return the punt for a touch down and build an injected turbo water inter cooled 2F.
I already have a worked 2F that rocks that's been rebuilt and balanced, tomorrow I pick up a 3F-E complete for $200us that was pulled out and replaced by a 350 in an 80 series . It was running when removed too.
My 2F, the last dyno run. So we know where we started.
First up will be to remove the 3F-E head and have it worked, ported and polished plus what ever else it need to suit the turbo.
So for those interested watch this space for a detailed write up.
TEC SPECS COVERED SO FAR IN THIS THREAD. I will up date this as the thread progresses in RED links in ORANGE
3F-E Head ported polished larger flat faced Ferrea valves and flow tested before and after.
Con Rods for a Jaguar 4.2 straight 6 will replace the stock 2F rods
Pistons JE Custom
ECU Wolf V500
Turbo is a by Garrett GT30 82R
Valve Springs by Crow Part No4832
ARP Con Rod Bolts Part No 154-6001
Wastegate Tial 44mm
Home Brew Intercooler Air to water
Jet Hot Ceramic Coatings
TLF Performance Parts 550cc Injectors
Davies Craig Electric Water Pump for the Intercooler
READING
New Features compares the 60 series 2F with the 62 3FE
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 01-31-07, 03:45 PM   #2 (permalink)
my64fj40's Avatar
Should be interesting.
Lookin forward to it.
"Jeep, it's what's for dinner."
1964 FJ40- 406 SBC - TH350- HFS 4in- Detroit in rear- 35s
Build Thread:
http://forum.ih8mud.com/showthread.p...87#post1089087
my64fj40 is offline   Reply With Quote
Old 01-31-07, 03:48 PM   #3 (permalink)
In the garage
John Smith's Avatar
TLCA# 9074
Could you explain what that means for those of us who are dyno and metric challenged? I read it to say that peak torque is reached around 3000 rpm then levels off? I look forward to seeing this build up thread.
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 01-31-07, 03:55 PM   #4 (permalink)
Peak Torque @ ~2000, peak HP @~3000-3500. (Lines are labeled P and T).
Doug G
Seattle, WA
TLCA#12671
lovetoski is offline   Reply With Quote
Old 01-31-07, 03:57 PM   #5 (permalink)
what he said
Mace's Avatar
TLCA# Something
So you max out the RWHP at 100 (75 KW) correct?
With 368 Ft lbs of torque? (500 nm)
interesting..
I hit 140 hp and 220 ft lbs in my rig.
How did the torque numbers get so high without much increase in HP?
I am kinda gay.......
My Myspace
Old 01-31-07, 03:58 PM   #6 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
I'm assuming from the torque/power curves that this must have been with a stock camshaft.
Any induction, exhaust or compression changes to that engine?
What sort of loss are you attributing to the drivetrain (what sort of flywheel numbers do you think these approximate)?
Mark W is offline   Reply With Quote
Old 01-31-07, 04:00 PM   #7 (permalink)
Lifer with a 2F-ETI
Red is Gas Blue is LPG as for the Metric coversions sorry I'm imperially challenged
Links
Mac's Space
On the rev limiter
Old 01-31-07, 04:05 PM   #8 (permalink)
numtel's Avatar
TLCA# 14946
Wow you got more power on propane? I'm asssuming you must have adjusted the timing when switching right? Is there anything else you did?
I run gas and lpg in my cruiser too but I don't think I have a power increase with the propane.
numtel is offline   Reply With Quote
Old 01-31-07, 04:09 PM   #9 (permalink)
Lifer with a 2F-ETI
The original 2F was built and cammed for low down torque on LPG the head was skimmed and a few other bits. So it's tuned for LPG
This engine was built for torque not hp to turn 35's. Diffs are 4.556 too.
30 spline Longfileds in the front as we snapped a stock CV every trip out.
Links
Mac's Space
On the rev limiter
Old 01-31-07, 04:19 PM   #10 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
I've got a 2FE-T cooking on a back burner myself. Down the line a bit, so I'll be watching your build with interest.
Mark...
Old 01-31-07, 06:19 PM   #11 (permalink)
Lifer with a 2F-ETI
First the engine builder wants the 3F-E head which is stock to calculate the volume and compression from there he will if needed open it up.
It seem that to get more out of the turbo it may be better to de-compress the engine, rather than incress it. All this can be done while its been ported and polished.
Big learnig curve for myself here too.
New forged pistons will be needed as well as con rods. Crank I'm told is not an issue cam has not yet been discussed.
Now where is my credit card
I'll take pics of the 3F-E head before it goes to be machined and post up a full list of the modifications and after pics.
Links
Mac's Space
On the rev limiter
Old 01-31-07, 06:39 PM   #12 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
I don't think you will need any change to the connecting rods. Rod bolts are the weak link.
Nominal compression on a 2FE *should* work out right at 9.0:1 A little on the high side for a turbo, but it you're gonna be running an intercooler it should be okay.
Mark...
Old 01-31-07, 07:12 PM   #13 (permalink)
Lifer with a 2F-ETI
Mark...
Just off the phone with the turbo people they would like the engine to make around 8.0:1 so that's sorted if need be the head will be opened up to achive the required compression.
Also to run boost up to 20 psi I should have the the head or block O'ringed
I'm learning real fast.
Links
Mac's Space
On the rev limiter
Old 01-31-07, 08:52 PM   #14 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
Yeah I was assuming a max boost of 15 psi. I'd be happy as hell to make that work.
Mark...
Old 01-31-07, 10:32 PM   #15 (permalink)
what he said
Mace's Avatar
TLCA# Something
20 psi is nuts..
stick with 12-15 psi boost...
at 2000' elevation with a 8:1 compression ratio under 15 lbs of boost you will have an approximate effective compression ratio of almost 16:1
At 20 psi you are lookin at about 19:1...
My Myspace
Old 01-31-07, 10:43 PM   #16 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
But the concerns of a supercharge making cylinder pressure in conjunction with the pressure made by the compression of the piston moving up are not the same as an equal amount of presure made by compression alone. And an intercooler reduces the equvilency even further.Cylinder temps and detonation is not the same because of the amount of heat actually generated outside of the combustion chgamber and (in the case of an intercooler) shed there too. Not to say that even 12psi of boost is not a LOT.
Mark...
Old 01-31-07, 11:10 PM   #17 (permalink)
Klunky Chris's Avatar
TLCA# 4821
yea.... my 87 supra turbo is running at what..... 6-8PSI?!?
Chris Basehore TLCA# 4821
74 FJ40- built F, knuckles/brakes from a FJ60, Longs, 4" Pinnacle sucks big wads, mini PS, shite paint
93FZJ80 "klunky"- E-lockers, home built sliders, IronPigOffRoad bumper, CDL switch, D-less, mucho maintenance
www.ILUVROCKS.com
Klunky Chris is offline   Reply With Quote
Old 02-01-07, 12:17 AM   #18 (permalink)
Lifer with a 2F-ETI
Without adding the O'rings to the head or block the turbo people here only recommend a max of 10psi. It's seems the O'rings aid the cylinder head gasket so a higher boost can be run.
Like I said before I'm learning as I go. but for myself I think 15psi max would be the go rather than pushing the limits too far.
Other issues I have yet to address are fuel pumps and gas convertors to cope.
Links
Mac's Space
On the rev limiter
Old 02-01-07, 12:43 AM   #19 (permalink)
... Alive
Mark W's Avatar
TLCA# 6303
Considering that 15 psi will basically double your power... Yeah, I'd say that's plenty and I'd be more than happy to reach that level. (Don't forget that there's a lot of room to boost the power of a 2F BEFORE you get stated with boost!)
Before anyone lurking this thread jumps in with smarmy comments about polishing a turd or the old "put a smallblock in it"... Same reason mountains get climbed... Because it's there.
Mark...
Mark...
Old 02-01-07, 02:31 AM   #20 (permalink)
Lifer with a 2F-ETI
Mark...
Mark...
I get all the V8 comments and not a cat in hells chance, the look on someones face with an all powerful V8, been beaten at comp by a 2F is PRICELESS
Some of you may have seen this before its posted here and there on this forum. Me at play on my AT's
http://scotto.3rdrock4x4.com/MattMc40.mov
As you can see My current 2F turns 35's nicely
Links
Mac's Space
On the rev limiter
Old 02-01-07, 08:10 AM   #21 (permalink)
my64fj40's Avatar
I imagine all this work isn't "Priceless" though.
So how much $ do ya have in it or gonna have in it??
Build Thread:
Old 02-01-07, 08:22 AM   #22 (permalink)
Lifer with a 2F-ETI
Turbo, intercooler, ECU, custom maifold $5,500us
Drop forged pistions $2,000us
3F-E $231us
Work to the head $2000us
Always add 20% sunderies
Spent so far on the truck just under 40,000us including all maintenance from competing. writing off rebuilding, fixing breaking and improving.
It's a labour of love and I have two ex wifes so the sig below is true to form
Links
Mac's Space
On the rev limiter
Old 02-01-07, 08:43 AM   #23 (permalink)
what he said
Mace's Avatar
TLCA# Something
I am still not convinced on an intercooler. Seems water injection would be better and easier.
I max out at 12 psi on my turbo...
My Myspace
Old 02-01-07, 08:58 AM   #24 (permalink)
Lifer with a 2F-ETI
Water injection???
Links
Mac's Space
On the rev limiter
Old 02-01-07, 09:11 AM   #25 (permalink)
what he said
Mace's Avatar
TLCA# Something
http://www.rallycars.com/Cars/WaterInjection.html
http://www.rbracing-rsr.com/waterinjection.html
http://www.hackaday.com/2005/06/25/h...ter-injection/
Water/alcohol...
My Myspace
Old 02-01-07, 09:46 AM   #26 (permalink)
Lifer with a 2F-ETI
Tks all very interesting reading I'll chat to the turbo charging place about it, see what they know and how it stands against an intercooler system.
Just one question how much water/alcohol do you need to carry eg an extra fuel/water tank to match 30 Gal of fuel. (If I have both fuel tanks full)
Links
Mac's Space
On the rev limiter
Old 02-01-07, 10:11 AM   #27 (permalink)
what he said
Mace's Avatar
TLCA# Something
bout a quart or so.. It really does not use much water at all..
My Myspace
Old 02-01-07, 10:50 AM   #28 (permalink)
Pin_Head's Avatar
Before anyone lurking this thread jumps in with smarmy comments about polishing a turd or the old "put a smallblock in it"... ...
OK, How about putting a racing saddle on a mule?
It is still a mule.
Drop forged pistions $1,000us
3F-E $231us
Work to the head $1000us
For that kind of money, you could get a real racing engine and not just a curiosity.
Pin_Head is offline   Reply With Quote
Old 02-01-07, 10:52 AM
Pin_Head
This message has been deleted by Pin_Head. Reason: double
Old 02-01-07, 10:54 AM   #29 (permalink)
Lifer with a 2F-ETI
It is still a mule.
But how do you feel when you're beaten by the mule
And for that kind of money I will get a real racing engine Just not a racing car
Links
Mac's Space
On the rev limiter
Old 02-01-07, 11:29 AM   #30 (permalink)
Pin_Head's Avatar
I will be rolling on the ground laughing when the "mule" has a rod sticking out of the block. You can't make chicken salad out of chicken $hit.
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/134529-2f-3f-e-%3D-2f-eti-into-my-fj40.html
Posted By For Type Date
[3FE] Re: 3FE Turbo This thread Refback 05-04-09 04:09 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-11-09 10:19 PM
Turbo or Supercharger on 3F Cruiser? - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 03-15-09 04:05 PM
FOROS DE NUESTRO CLUB • Ver Tema - Potenciación exitosa This thread Refback 03-11-09 09:50 AM
2F Turbo/Super Cargado - foro.cruiserheads.com This thread Refback 03-10-09 02:29 PM
Laminova water to air intercooler - Page 3 - Patrol 4x4 - Nissan Patrol Forum This thread Refback 02-21-09 05:57 PM
1hz flow rates - Pirate4x4.Com Bulletin Board Post #0 Refback 12-29-08 08:06 PM
Chilled intake...? - Page 3 - Cummins 4BT & Diesel Conversions Forums This thread Refback 11-30-08 09:34 AM
Outer Limits 4x4 Board :: View topic - changeing 3FE auto to 3F carby manual This thread Refback 11-07-08 12:50 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 07-14-08 02:28 PM
2f + 3f-e = 2f-eti Fj40 - Rising Sun Member Forums This thread Refback 06-05-08 04:04 AM
Untitled document This thread Refback 05-11-08 12:39 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-15-08 12:46 PM
The Best Carb? - Pirate4x4.Com Bulletin Board This thread Refback 04-11-08 10:00 AM
Toontoys Forums :: View topic - WANTED - BJ60 Land Cruiser This thread Refback 03-09-08 10:12 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 07:19 PM
1983 FJ45 Troop Carrier Buildup - Page 24 - Expedition Portal Forums This thread Refback 02-21-08 12:29 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 01-22-08 03:57 PM
Turbo 2f... - Rising Sun Member Forums This thread Refback 12-20-07 01:39 PM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-17-07 12:34 AM
Outer Limits 4x4 Board :: View topic - 6cyl stroker kits This thread Refback 12-16-07 08:27 PM
