ARCHIVE Group purchase on shift plates 3-4-5-speed-automatics-twin stick
Did you get any plates made with:
5 speed
H 2wd
N 4WD
L
I am pretty sure that is what Georg was interested and I am deffinitely waiting around for one! Let me know thanks!
I emailed him multiple times in regards to a design drawings and never got a response.
You don't make anything that would match the FJ62 setup? Those automatics do not have a button for overdrive but four positions on the shifter. Plus the 4WD is vacuum so the shifter is 2H-n-4L
I'm sure there's lots of configurations that I don't make. Covering the basics first.
I understand. The length of the A440F with split transfer isn't a popular choice in the 40s. Installing that setup in a FJ45LP-B the height not length is the biggest problem.
This is sort of what I had in mind, I would have sent this a while ago had I known...
Hey AATLAS1X,
This is what I had in mind, as far as the 'Narrative' I think the original one I stole from one of your Automatic plates will do just fine, it seems like something Toyota would write, my 2wd & 4wd fonts are probably not correct but can be corrected to match yours. I am open to your input and anyone else interested in one of these, let me know thanks, Kevin.
Make the 2wd-4wd bigger? or leave it? I have a photoshop document of this whit layers, and I have higher resolutions.... based of your original high quality jpegs AATLAS1X
Here is the thread where I started to want one of these, it may do someone good if it is attached?!?!:
https://forum.ih8mud.com/metric-tlc/215155-new-glove-box-shift-plates-3-4-5-speed-2.html
Hey AATLAS1X,
Alright! This is the one I need. It would be great if the 2wd and 4wd are bigger, to match the H-N-L.
Thanks, Ron
5 speed
H 2wd
N 4WD
L
I would be in for one of the 5 speed TS as above. Ok to wait for these to be done.
The post above looks perfect.
:cheers:
Steve
Still need 3 speed auto and transfer case twin stick configuration like this:
:meh:
Purchased the four speed plate/twin stick for my 420 and Atlas in the Red truck.
You really should call sometime Shane.
I looked hard for that thread last night and could not find it...... Thanks.
Ok, so I am crystal clear, that art above is what you would like so see.
Do you want the 2wd and 4wd circle to be larger and the 2wd and 4wd larger as well?
I sent you an email, please reply with the layout you like and I will get working on it.
Thanks again
Shane
that sounds good man!! I think that will work just fine!!
[URL="http://farm9.staticflickr.com/8232/8517616028_21faa5a277_b.jpg"][/URL]
Thanks again
Shane
