Hello Guys,
So last week I pulled apart my gauge cluster apart to clean it up and do the light shields mod, then put it back together the way it came apart. I also pulled the headlight switch out to repair the broken rheostat for my dimmer switch (I had to solder one of the rheostat loops because it was broken near the bright end.) Both, I have put together just the way that I took them apart. But now, my temperature gauge is pegging on high, and my fuel gauge may or may not be pegging also. (Can't remember how much I've driven since I put fuel in it) My ammeter and oil pressure seem to be working fine though. Everything worked just fine before I pulled them apart, so I really rather doubt something went bad... I've pulled everything out to double check... Haven't seen anything out of order... Felt the engine to see how hot it was, warm, but not more than normal, (In fact it was cool, I could stick my finger in the coolant.) I had just started it, it ran for about 3 minutes when it started climbing and now climbs every time I turn the key on. The thermostat is new as is the temp sensor. ( I also knocked on the thermostat housing in case it was stuck)
Any thoughts? I am wanting to put my on new Alcan
lift, not be tearing apart stuff I should be done with!
Thanks for the input Guys!
to all!
