No spark/ignitor hook up?
I just installed my hei on the 2f that I put in my 71 FJ (convert from the 1F0
I have voltage at the + and - side of the coil
I have voltage with the ignition sw on to the + side (red wire from solenoid) and voltage when key is in start pos
I used a jumper lead and grounded the ignitor mount but it is bolted tight on one side into the head as well
No spark from coil wire
I have 2 wires hooked to the coil-- the ign wire and the hot wire from the solenoid
1 green connector plugged from the ignitor to the distrib
with the key on the two gree connectors i am holding have power, the one with two tangs only has power on one of the tangs.
any suggestions, is there something I am missing hooking it up?
