Hello
does anyone know if a 1000lb engine stand is ok or should i get a 2000 lb?
Have fun bolting it up to the stand.
he is a real tricky guy...easy if you take the top off the stand then bolt it to that first... then just lift the stand up to the top.... lower down and the only thing you got to worry about is the stand not hitting the cherry picker... worked for me...
btw thats another Ed trick...he is a real tricky guy...
With out modifying the arms, I have only seen one 2F bolted to an engine stand using all 4 bolts. An that was Bulington's picture. Three bolts is not a problem but that 4th one is not going to happen without some mod work. I have three engine stands and three different brands. LOL!
Harbor Freight special stand and easily got all 4 bolts in AND used all four arms!![]()
