saginaw steering box fab question
Charlotte
Alright... I can't seem to get a call back from some of the vendors, so I thought I'd poll the group.
What are the dimensions of the holes you drill in the front crossmember to fit a Saginaw 800 series box to a 40, and what are the OD and ID of the tube that you use to sleeve the hole.
(I guess that the tubing answer will provide me with the others) :rolleyes:
TIA,
Jim
Really it depends on the kit. Most start with a 3" in the front and smaller in the back depending on the angle and depth of the box. Some require a cut be made to recess the box further. If you start with a 3" hole use a 3" sleeve if it doesn't interfere ith the box.
iirc 83mm or 3 1/4 hole saw will do the trick
and a 3" sleeve
