I have had this small compressor that I have used the past few years to air my tires back up after running the trials. I have pulled it out of my rear storage drawer and walked it around the truck as I aired up each tire. Its not that big of a deal to do, but its just a hassle to put it all away after I’m done. I have always wanted to do what “Kanaljen” did with his and copied his set up. His write up can be found here! What his write up didn’t show was the mount/bracket, so I figured I would post up how I built mine. I leveraged the bolt holding the air box in place as well as an existing hole in the finder to secure the bracket. I used a notched piece of steal so that I can access my headlight bulbs without having to remove the compressor if one burns out. I will be removing the little air filter from the air pump and plumbing in an air hose from the pump to the trucks air cleaner to pull cooler air into the pump. I will be working on the rest of the plumbing of the air hose this week and I will keep you all posted on what I decide to do.
