Every Y-radius arm I've seen has the long part on the bottom, and the short part on the top. Like this:
Better build it strong, or you are going to bend that upper link right where the lower Y hits it.
The lower link is in compression. The upper link is in tension. By mounting the lower link to the upper link instead of vice versa, you are putting a significant stress in the middle of the upper link.
well, except, as I said, when it's on the rear of the vehicle - the tension is replaced w/ compression. This same y-link style is used in the rear.
That and the long link, that you say is going to get bent, it doesn't take any more or less force to bend it if I'm pushing on it with the short link than if I'm pulling on it.
why do you want to flip it?
Why a radius arm setup at all?
They are a compromise and not known for articualtion.
Moving them up like that really does not benefit you that much. Rarely have I seen links actually hinder your movement on the trail. Something else hits instead.
they do o.k.
https://forum.ih8mud.com/80-series-tech/294260-jodo-97-lx450-coilover-project-6.html#post4643102
This is for the front of a 6,000 lb 80 series that drives nice down the road that still needs to drive nice down the road. It's already got radius arms, just because of the radius arm design they bind alot - alot more than Y-links. There are plenty of threads in the 80's section about how bad radius arms are, about how good they are, about how good 3-links are, how bad and unsafe 3-links are. Lots of opinions, very few with experience - Dusty's an exception. If I asked the question in that section, I'd get all kids of arguments about why I should or shouldn't keep radius arms. I didn't want that arguement, just info on how to build them.
I'm not looking for huge articulation gains, just a little, and a little moving the axle forward to get the tires out of the fender wells.
