Winch power lead - hook up question
Discussion in 'Winching and Recovery' started by PDoyle, May 9, 2009.
  1. PDoyle
    PDoyle
    1,943
    26
    Oct 5, 2003
    Saratoga Lake, NY
    I have 2 vehicles with a class 3 hitch(es) on front and rear .
    I ran "battery cable" with connectors from the battery areas to both front and rear. The winch has cable and an SB175 plug at the end, to match the cable.
    I want to use my current battery as a power source, and hook up all cables to this battery.
    Need advice on what to do further to attach all cables to the power source.
    Thanks.
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,008
    Media:
    17
    249
    Oct 1, 2003
    MN
  3. PDoyle
    PDoyle
    1,943
    26
    Oct 5, 2003
    Saratoga Lake, NY
    Ok, but which ones? I've looked at those.
    I have terminals from the vehicles attached to the battery. Can't add more terminals to the 2 top posts. The cable ends have the eyelets attached. Is there a top post terminal that has an adapter I can add the eyelets too?
  4. cody c
    cody c
    4,641
    23
    Feb 20, 2006
    calgary
    There should be a way to make this work, do you have a picture? I dont really understand your situation from this post. You should have a look at dual battery setups, quick disconnects and maybe power splitter bars for your setup if you plan to be winching alot.
  5. PDoyle
    PDoyle
    1,943
    26
    Oct 5, 2003
    Saratoga Lake, NY
    Finally got around to taking a pic... This pic of the battery and cables attached the correct way. Also in the pic is the positive cable from my winch hook up. It has a round clasp with the nut & bolt. The neg. cable is attached to the frame closer to the rear of the truck. I have 2 more cables ( pos and neg.) in the front winch hook up. The gold piece is a terminal I bought at a custom stereo store a while back. Not sure if it is any use though.
    I'm looking for a way to attach the 2 positive cables and 1 negative cable to the battery with of course the vehicle cables attached as well.
    Or is there a special fuse block that will take care of this?
    Thanks 4 any help.
  6. PDoyle
    PDoyle
    1,943
    26
    Oct 5, 2003
    Saratoga Lake, NY
    Danka! I'l check these out. But I have to cut the end off the cable and add an eyelet.
