Why does my oil light come on all the time?
Discussion in '80-Series Tech' started by Outback, Sep 19, 2003.
  1. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    My oil light comes on, sometimes only 1000 miles after an oil change! It doesn't use oil to make a difference, maybe .5 quart or so between 3K mile changes :rolleyes:
    It's just annoying me to death :mad: What gives? I check the oil regularly. Anyone else have this problem?
    Jody.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Hi Jody,
    I assume you are talking about your 93 FZJ80? The light indicates a low oil level in the oil pan. If you are sure that your oil level is correct you may have a failing sensor.
    The part number is 89491-60010 and it lists for $312.23. It is also possible that the wires leading to it may have a problem.
    Dan.
  3. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    CruiserDan,
    How far down does the oil have to get to "normally" actuate the oil light?
    I'll check into the wires as soon as I can though...
    Jody.
  4. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Some say about a quart low, I've filled mine a quart low during an oil change to see if mine would come on and it did not. I have had it come on during an extreme nose-down descent in the Rio Puerco. (spooky steep). I guess it could vary from engine to engine. I would guess anywhere between 1 to 2 quarts low at the max. If the level were close to low, some sudden movements (like a fast turn) would flash the light momentarily.
  5. landtank
    landtank SILVER Star
    18,421
    601
    Mar 27, 2003
    Groveland MA
    Have you checked the level while the light is on? Just to be sure you don't have an oil return issue.
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    The oil sensor float on the Toyota Previa van needed to be replaced, at least that is what the used car dealer said. The low oil light was on. I removed it and it has a float that slides on a shaft. It would get stuck on the shaft. I sanded the shaft with fine sand paper till the float would slide on the shaft. Cleaned it up and installed. Worked fine after that.
    I would assume that the floats are about the same on the Previa and 1FZ, C-Dan???
  7. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Kurt,
    The part numbers are different but the function is the same. Your fix would certainly be worth a try before the billfold comes out.
