Order placed sir. Thanks.
Ok. So, I have an evening of time on my hands. How difficult is it to install springs for a 2" lift. If it didn't get done tonight it isn't end of the world because I can drive my 92 tomorrow. I hear the back springs will basically just fall out when I lift it by the frame. And the front I need a spring compressor or something. I've never done this but am feeling up to a challenge!
Easy peasy. Fronts: Disconnect the lower shocks, jack up from the axle with floor jack and put 2 jack stands on the frame. Remove tires. Remove floor jack. Should give you enough droop on each side to get the old out and new in without compressing the spring. REAR: same thing but the bottom shock bolts can be a bit of a pain and if they snap, in for for some more work.Ok. So, I have an evening of time on my hands. How difficult is it to install springs for a 2" lift. If it didn't get done tonight it isn't end of the world because I can drive my 92 tomorrow. I hear the back springs will basically just fall out when I lift it by the frame. And the front I need a spring compressor or something. I've never done this but am feeling up to a challenge!
You will love them. Great product. I solo installed mine also! I never appreciated my jack stands until that install!
on MT, they are typically pretty good about that stuff. But in the end you got a nice product. I love mine.Yes, I have a fondness for my jack stands now too!!
The kicker for my purchase is that I'd emailed MT quite a few times about them and never heard back, and I tried calling quite a few times and never could reach anyone. All I was trying to do was find out an accurate shipping cost. In the end I saved myself a good chunk of change on sliders that only have a few scuffs.
I jack mine up only a few inches then support the frame with cement blocks topped with scraps of lumber and then remove the tires doing only one axle at a time for the sake of safety. Then, like others said, once the shocks and swaybar are disconnected, the axle will drop far enough. Removing the tires eliminates the need to raise the cruiser much. Post pics.... And of course a Tough Dog review.Ok. So, I have an evening of time on my hands. How difficult is it to install springs for a 2" lift. If it didn't get done tonight it isn't end of the world because I can drive my 92 tomorrow. I hear the back springs will basically just fall out when I lift it by the frame. And the front I need a spring compressor or something. I've never done this but am feeling up to a challenge!
Unbolt the shocks and the fronts fall out too. No spring compressor needed.
That's the jest of it at least. Done my 3 times solo without to much headache.
I find the rear lower shocks are easier to get back on if you pound them with a 2x4 and a hammer. Unless your bushings are fried, in which case, they will slide right on
I have sometimes had someone stand on the brake to fully droop out each corner.
It's easy. Just unbolt bottom of shock and sway bar then put a small 4x4 block on the jack
I think it took me 4 hours to do springs and shocks, didnt need a spring compressor for a 2.5" lift. Remove sway bar brackets and let them drop. The rear was simple as you mentioned, the front may need to loosen the shocks, and using the bottle jack to push the axle down made it easier.
Rear sway brackets (To frame) bolts shear easily, so careful there.
looks like he's got some aussie in him.
Yea so, you're not the first one to say this haha. He's registered with the American Border Collie Association who favor working skills over coat color, hence the merle coat. They do look strikingly similar though, biggest difference being an undocked tail. I ended up with this guy cause his temperament matches my family's lifestyle well.
I like those working dogs and want to get one for my next dog. My Lab is 12 and, although she is doing very well, I'm thinking about the new puppy already. The other day I had my dog at a huge park exercising her and a guy showed up with an Austrailian Sheperd puppy who was fearless and sort of crazy. This puppy looked like a border collie but was 100% Austrailian sheperd.Yea so, you're not the first one to say this haha. He's registered with the American Border Collie Association who favor working skills over coat color, hence the merle coat. They do look strikingly similar though, biggest difference being an undocked tail. I ended up with this guy cause his temperament matches my family's lifestyle well.
