WATER CONDENSATION AND WHITE SLIME
Discussion in '40- & 55-Series Tech' started by Eric, Jan 13, 2003.
  1. Eric
    Eric
    2
    Feb 26, 2002
    A few months ago I THOUGHT that I was loosing coolant and I had water condensation and a white slime build up on the underside of my oil fill cap. I figured a leaking head gasket or cracked head. I pulled the head and had the machine shop take it all apart, cook it out, magnaflux (they found no cracks) , cut smooth, clean all the valves and put back together with all new seals (I also cleaned the top of the pistons) . I put the head back on with a good Fel-Pro gasket and torqued all the bolts to 95ft pounds in the correct order. Put every thing else back together and it fired right up. Adjusted the valves and off I went. It probably runs better now then it ever has (very strong, no hesitation, no backfires and no smoke) . But I am still getting water condensation and white slime on the underside of my oil fill cap. I am confident the head is sealed perfect but where else may i be getting coolant OR WATER in my oil? At least that's what I'm guessing is causing the water condensation and slime. What is the possibility I may have a internally cracked block in the water jacket that is allowing coolant to get into the oil? Or would I have other symptoms if the block was cracked? I also heard that this may be caused by a bad PCV valve? But I replaced it a little while ago and I believe it is working fine This is a 74 FJ-40 with the F engine. thanks for any possible ideas!!!!!
    Eric
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    I-6s are notorious for getting condensation here if they are not driven much. Is it getting good and warm? Is it driven very infrequently? Does the oil look OK? Is the exhaust smelling OK? You might be chasing normal condensation.
  3. Eric
    Eric
    2
    Feb 26, 2002
    I do drive it infrequently (1-2 times a month) but when I take it out I usually have it out for a while so it gets good and warm. maybe this still is not sufficient? It is cold here in PA. As far as I can tell the oil looks fine but I have been changing it every 1000 miles as I am afraid if water is getting into my oil it will start causing a lot of problems, so I have been changing oil frequently so it does not get diluted if their is a leak. maybe I should let it go for a while before I change it again to see if I can see any problems with it?
    Eric
  4. FJ40Dude75
    FJ40Dude75
    248
    Nov 12, 2002
    I had the same thing going on in my 75 rebuilt the engine and still did it talked to alot of people who all have said its normal as long as your not smokin or stuff like that and where in pa are you from ??I live in Allentown
  5. Gumby
    11,781
    310
    Dec 13, 2002
    Coolant will toast your bearings in a hurry. No doubt, but the oil will turn chocolate-milky if it's getting in there. If it's mostly burning off the exhaust will smell bad like sweet anti-freeze and there will be a lot of steam. Do you have any build up on the plugs yet? water in the combustion chamber will blow off build up and you might have a very clean plug on one.
  6. pfry
    pfry
    64
    Feb 17, 2002
    You might try an oil analysis.
    Many auto parts stores sell the kits. Draw a sample, send it in to the lab, get results.
    Paul
