Alright people smarter than me (aka everybody).
Parked the FJ40 in 2005. In 2007, pulled the carb, drained oil, emptied radiator. Then nothing. Stupid. Fast forward to 2016.
Trying to get her running again. Sludge everywhere. Cleaned everything. Pulled the head, had a valve job done. Reassembled. OEM gaskets everywhere. Today, I finally tried to start. Initially, no dice. Cranking over but wouldn't fire. Eventually figured out that my timing was off. Set #1 cyl to TDC with the timing mark aligned, and set the distributor rotor to #4 spark plug. Was able to fire. But will only run with the choke out. Under 1000 RPM, she just dies. I was able to time it though, kept her at 950ish and set her to 7 degrees (BB aligned to needle)
Other big thing pointing to vacuum leak. When the timing was off, and I was flooding the carb, I noticed some gas dripping down the drivers side of the block. Looked like it was coming from the intake manifold near cyl #4 or 5. Probably from between the intake, gasket, and block.
So what next? Tighten all bolts, esp around where I saw the gas? Spray carb or brake clean fluid around the intake/exhaust and look for an idle surge? If the intake/exhaust bolts are all tight, do I have warping and have to pull them (intake/exhaust manifolds) again and machine?
I almost am ready to burn the thing to the ground. Learn from me. Don't park your truck for 10 plus years! If you do, do a much better job prepping it!
Thanks
Thanks
