Wondered if others with V-8's or saginaw ps conversions have the same problem and if so have found a long term solution.
What I have: 1986 FJ60 with 5.7 Vortec V-8, PS pump is the 4wd version, I have -AN hose plubmed with two fittings in the gear and an external ps cooler in front of the condensor.
I'll post up some pics a little later.
Since the V-8 swap I've had about 3 ps pumps (rebuilt napa, advance, even GM)...
Symptoms: While is 2wd no issues, either on road or off road. Once off road and in 4wd I get PS pump groan / noise after aggressive hill climbs and pro-longed use of 4wd. As long as I'm on a steep hill requiring 4wd for whatever reason the pump is noisy...once I get to a better location and turn off 4 wd the pump will eventually stop making noise.
I'm wondering if the ps fluid is getting too hot and maybe I need a larger cooler? Because the first couple of runs using 4wd I'm ok...then later on in the day as soon as 4wd is engaged...the pump starts the noise routine.
I'll show the current setup of the cooler with some pics as soon as I get a few pics taken. I'm runnign an Earls stacked plate cooler with -an fittings. I did have to use a -an to nipple fitting to get the low pressure hose to fit on the pump resivor hard line low pressue return to resivor.
THe only unique things are the ps cooler and the an to nipple fitting adapter.
http://www.summitracing.com/parts/EAR-21006ERL
I'm wondering if there is sufficient air flow across the cooler and or the cooler is just not big enough.... other than that I'm really out of ideas... I do have an adapter from -6AN down to roughly a barbed 3/8 hose that feeds the ps pump...this is the only other item that I think might impact the flow but not sure how to solve that if it is the issue. WHne I get the pics up you'll notice a gap between teh cooler and the condenser and i'm not sure how well that the cooler functions and how well the air flow is across it....especially off road when low speed and you are dependent on air flow across the radiator driven by the fan rather than speed of the vehicle as happens on the pavement at speed (air pressure in front of the radiator)...
