Type T-IV ATF
Discussion in '100-Series Cruisers' started by Desertmaster, Sep 20, 2004.
  1. Desertmaster
    Desertmaster
    250
    Mar 28, 2003
    I called Redline Oil and Amsoil Tech Support Dept.'s and they told me that they have nothing compatible with Toyota Type T-IV Trans. Oil.....to the contrary....the dealers for both Mfg. quoted me different......just wanted to save someone a huge and a coastly mistake in case you plan on replacing your ATF....just make sure it is Toyota Type T-IV.
    Also see the following thread on the 80-series:
    http://forum.ih8mud.com/showthread.php?t=22554
    Thanks
    Al
  2. 98LXand99LC
    98LXand99LC
    532
    7
    Dec 29, 2003
    Orlando, Florida
    Ok, that thread is making me nervous. I've replaced both of my 100's ATF with Amsoil. What will happen????
  3. Augie
    Augie
    511
    Nov 16, 2003
    My 99 factory repair manual specify Dextron II or Dextron III. There is nothing special about the fluid.
    Where did you find that spec?
  4. Desertmaster
    Desertmaster
    250
    Mar 28, 2003
    I have verified the info via the Owners manual as well as the dealer's Master mechanic (Toyota & Lexus) to confirm my findings...and they indicated to me that they never utilize Dextron II or III in any transmission that sits behind a V8 engine...as well as all Lexus models even the ones that have V6 and Straight 6 have been updated to Type T-IV ATF starting from 00 and up..... as for prior years 98-99 I was told only the V8's had the Type T-IV ATF........also I was told by the same master mechanics that a mixture of Dextron II or III with Type T-IV is not recommended at all...he never elaborated on what would happen if indeed someone made the mistake.......I did referenced to them that the Repair Manual is indicating Dextron II or III......their reply were: mistakes are common in those repair manuals as Toyota always issues a correction to the manuals based on the feed back they receive from the field technicians.......Sorry about the long post.......I hope I covered everyone's concern.
    For of those who had mixed the two type of ATF's.....I would look to do a full flush through the cooler lines and replace it with the correct fluid.....again this is my $0.02....I would advise you to contact the dealerships near you and verify the accuracy of this info......I have done that and most of the dealers I spoke with they confirmed it.
    Note: Please keep in mind that the 95 - 97 FZJ80 has the same transmission that goes into the 98-99 100 series....so that could be why we are seeing the Dextron II or III being mentioned in the repair manual......it could be carried over by mistake from the older model manual.....but again......this is me thinking loud....please do your diligent do and contact the dealers near you to verify it.
    Thanks
    Al
  5. NMuzj100
    NMuzj100
    3,480
    14
    Sep 25, 2004
    Gleneagle, CO
    AMSOIL Universal ATF meets T-IV requirements
    The following is an email I sent to AMSOIL Technical Service after seeing that their Universal ATF was recommended on the Website (Corporate, not a dealer) for use in trannies requiring T-IV fluid.
    I have a 2004 Toyota Landcruiser (UZJ100) and the owner's manual recommends Toyota Type IV automatic transmission fluid. How is this different from the Dextron III fluid recommended in earlier model years using the same transmission and should I use the AMSOIL Univesal ATF or stick with a dealer supplied Toyota Type IV fluid ? I noticed that the web site recommends the AMSOIL ATF but Toyota Type IV is not listed on bottles of AMSOIL Universal ATF. Thanks​
    AMSOIL Reply
    Thank you for contacting AMSOIL with your concerns.
    In response to your inquiry, reformulation of AMSOIL Synthetic Universal Automatic Transmission Fluid (ATF) was not required to attain the Toyota Type T and T-IV ratings. Therefore the labels don’t reflect the rating, as this is a relatively recent change.
    Thank you again for the opportunity to respond to your concerns. As always, please feel free to contact us again if we can be of further assistance.
    Sincerely,
    Jim Van
    AMSOIL Technical Services ​
    I am running AMSOIL ATF in my UZJ100 and feel very safe doing so. I am thinking that T-IV is essentially a high-quality Dextron III like product, perhaps even semi-synthetic (like MERCON V) and that is why Toyota has moved to it but AMSOIL Universal ATF did not have to be changed to meet the requirements. I would still like to see the T-IV approval on the bottle. My semi-synthetic theory makes the high price of the T-IV from a dealer seem more reasonable but I have never expected or received reasonable prices from a dealer.
  6. 98LXand99LC
    98LXand99LC
    532
    7
    Dec 29, 2003
    Orlando, Florida
    Nmuzj100,
    Thanks for the post. I feel a lot better about having made the switch to Amsoil.
  7. Desertmaster
    Desertmaster
    250
    Mar 28, 2003
    This is great....but I was never able to get the Amsoil technical rep. to say it is compatiable......and it is OK for both type of ATF's to be mixed.......like you said I still would like to see it reflected on the bottle...legally if anything goes wrong I would like to hold them accountable for the failure of my Transmission....but since it is not stated I will continue to utilize Toyota Type T-IV untill they reflect the compatibility factor on the bottle itself.......my $0.02.
    Thanks
  8. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,691
    284
    Dec 13, 2002
    Knee deep in hookers and gin
    I have just found out that Vavoline Maxlife is T-IV compatable. Unfortunately, it is not synthetic and cost almost as I just paid for T-IV. About 3.10 vs. 3.60 per quart. If your dealer hoses you full list it'll be closer to $5 for the TOyota.
  9. NMuzj100
    NMuzj100
    3,480
    14
    Sep 25, 2004
    Gleneagle, CO
    To Valvoline Customer Service
    Toyota reccomends a T-IV rated ATF fluid for the automatic transmission in
    my Landcrusier. Does Valvoline have a ATF that meets those requirements?
    The dealer prices for the Toyota fluid seem high and I am looking for an
    alternative.​
    And their response...
    THOMAS R. SMITH
    Technical Director, Valvoline Brand
    June 7, 2004
    To Whom It May Concern:
    Valvoline has received several inquiries regarding the topic of MaxLife ATF and its use in various vehicles beyond those requiring DEXRON-III or MERCON approved products. In response to these questions Valvoline has issued the following statements:
    Valvoline supports the use of MaxLife ATF in a broad range of transmissions beyond those requiring DEXRON III and MERCON fluids including those where the following fluids are recommended:
    o GM DEXRON II
    o Ford MERCON V
    o Allison C-4
    o Chrysler ATF+3 or ATF+4 fluids
    o Toyota (and Lexus) Type T, T-III or T-IV fluids
    o Mitsubishi Diamond SP-II or SP-III fluids
    o Hyundai
    o Honda ATF-Z1 fluid (except in CVTs)
    o BMW LT71141 or LA2634 fluids
    o Nissan Matic-D, Matic-J, and Matic-K fluids
    MaxLife ATF is recommended for the new 5 and 6 speed transmissions, except the Ford 5R110, Ford 6RXX, and the Mercedes Benz W7A700 (7G-TRONIC) which all require a low viscosity Automatic Transmission Fluid.
    Valvoline has conducted in-house testing to support MaxLife ATF performance in these transmissions. However, it is important to note that these vehicle manufacturers have neither evaluated nor approved MaxLife ATF.
    Valvoline stands behind all of its products, including MaxLife ATF. Use of MaxLife ATF in transmissions where recommended by Valvoline WILL NOT void the vehicle’s warranty. In the unlikely event that any transmission was to be damaged as a result of the use of MaxLife ATF, please contact Valvoline at 1-800-Team-VAL.
    While MaxLife ATF is designed to meet the special needs of higher mileage transmissions, new transmissionscan also benefit from its enhanced oxidation protection, shear stability, seal compatibility, and anti-shudder protection and many consumers have chosen to take advantage of this level of performance.
    Valvoline does not recommend MaxLife ATF for use in continuously variable transmissions (CVT’s) or in
    automatic transmissions where Ford Type F is recommended.
    Sincerely,
    Thom Smith
    Technical Director
    Valvoline Brand​
    So it looks like we have at least two aftermarket options for our T-IV Fluid.
  10. cruisermaine
    cruisermaine
    258
    Jun 3, 2004
  11. hank14
    hank14
    2,373
    34
    Nov 26, 2004
    Texas
    Yeah, I followed their instructions for the self flush when I bought my rig, and have been running all their fluids since July 2003.
  12. Pitbull
    Pitbull
    682
    2
    Oct 31, 2003
    If you own a 2004 LC with the 5 speed transmission that does not have a dipstick to check the fluid level you need to recheck your owners manual. It should say that you have "TOYOTA WS ATF" which is not compatable with any other ATF made. If it is mixed or contaminated with any other ATF it will cause you problems. The last year Toyota used Toyota type IV ATF in these transmissions for the LC/LX/GX and 4runner V8 was 2003, they switched to WS ATF in 2004. Hope this helps.
  13. Jim_Chow
    Jim_Chow
    2,479
    3
    Apr 28, 2003
    Turquoise Trail, N NM
    So does this mean one can only buy the special ATF from the Toyota dealer?
  14. Pitbull
    Pitbull
    682
    2
    Oct 31, 2003
    For the 2004 and 2005's that is what I've been told. I would like to know if NMuzj100, mixed his what happened? Is it still running? Maybe he did a flush and replaced all of the WS ATF with the Type IV ATF? But that wouldn't make sense since the WS is the latest and greatest. If the dealer flushed the WS and replaced it with the Type IV I would make them redo the work with the OEM WS fluid that the manual calls for. Hard to keep up with all these changes in fluid types and what works with what.
  15. Toylexmods
    Toylexmods
    68
    Dec 27, 2004
    Eugene, Oregon
    OK,
    Some confusion here. 98-99 LX470s need Dextron right? The owners manual states it, the service manual states it, the dipstick states it.
    What gives?
  16. NMuzj100
    NMuzj100
    3,480
    14
    Sep 25, 2004
    Gleneagle, CO
    The confusion is caused by Toyota changing transfluids every couple of years.
    1998-2000? - Dexron III - Lots of Aftermarket options
    2000?-2003 - Toyota Type-IV - Valvoline Maxlife, Mobil ATF 3309 and Amsoil (Synthetic)
    2003- - WS (World Standard) - Don't worry it's a "Lifetime" Fluid
    The main goal of this thread was to find out what options were available for Type-IV tranny fluids as it was pricey. The end result is that Amsoil technical support said that their ATF met Toyota - IV standards without reformulation (indicating not much difference form regular Dexron III) and since it is Dexron III compatible also it can run in any of the 4-speed auto trannies. The new World Standard (WS) is a totally different animal that apparently never needs changed or even checked :rolleyes:.
    My truck has always seen a Dexron III compatible product since it is a 1998.
  17. NeilC
    NeilC
    107
    Aug 26, 2007
    Baton Rouge, LA
    I have a 2000 LC. What fluid should I use? The preceeding post confused me thoroughly. Please unconfuse me.
  18. Jim_Chow
    Jim_Chow
    2,479
    3
    Apr 28, 2003
    It should say on the tranny dipstick.
  19. NMuzj100
    NMuzj100
    3,480
    14
    Sep 25, 2004
    Gleneagle, CO
    Neil C - Nice thread resurrection - 2+ years :eek:
    I wrote a long update in response and then lost it. I may try and rewrite soon.
    Until then check your dipstick for the right fluid and consider a good "multi-vehicle fluid" whether your truck is a DIII or T-IV.
    What year or at what VIN is the switch from DIII to T-IV?
  20. cary
    cary
    3,109
    16
    May 7, 2003
    The Specs for T-IV and Dexron are entirely different, one oil does not meet both. DO NOT USE ANY OIL WHERE T-IV IS CALLED FOR EXCEPT FOR T-IV. The price the dealer charges for the T-IV is reasonable.
