Trailer wiring harness 94
Discussion in '80-Series Tech' started by landtoy80, Sep 7, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I got the converter harness. Before I cut wires, do I cut into the wires in the signal assembly(where the bulbs are for brake,taillight and trun signals) are or is there a better place to tap into? I will use real wire conectors not the snap in ones.
  2. ParadiseCruiser
    ParadiseCruiser
    620
    Mar 27, 2003
    K -
    On the 95-97s, there is an OEM plug for the harness - intended for use with the factory tow package - no wiring cutting necessary (located on the PS in the area of the rear cross member). Double check with the pre 95 guys before you start hacking it up!
    Cheers, R -
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I think it not for the 94 and older :(
  4. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    The package for my plug-in trailer wiring kit (NAPA number 755-1470/Hoppy 18357) says it is for 91-97 L/C and 93-95 4 Runners. I have the pkg out because I am returning it to NAPA; it failed after only about 5 months of service - they say they will swap it out, no questions. Good Luck, BigMac
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Cool, for some reason I thought it was for 95 and newer. I checked on line and they also say 91 to 97. Its a good thing I asked I almost chopped up the wires and I don't like to solder. The OEM/dealer add on used snap on wire conectors and it didn't work when I got it.
    I will order one and see if it works.
    kurt
    I don't know what I would do with out IH8MUD
  6. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Kurt,
    I'm beginning to wonder if you do anything other than ih8mud.
    :D
    -B-
  7. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I brake things on the 80
    and look at my CETME :D
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I know what I would of done without the internet(preIH8MUD). When I had the fj60 I would of gotten fedup with all the problems I had getting it in tip top shape, that I would of never got the 80 and got a Double Cab Tacoma and saved a lot of $$$ :D
  9. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I looked at some harness and other than Hoppy no one has '95 and older plug in harness. Toyota or the dealer, sells '96+, along with a couple of others.
    If the Hoppy is '91 to '98 and the others only sell '96 to 98,is there a differance between the 96+ and 95 and older tail light wiring?
    kurt
  10. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,565
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
  11. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Then why wouldn't a 96+ work on my 94?
    Did Toyota sell the harness or is this a out source?
  12. cruiserdan
    20,565
    2,891
    Mar 27, 2003
    Toyota offered a splice-in and a plug-in harness. The year model applications escape me at the moment but you can use either one on 91-97. I can tell you that the current OEM converter/harness that is available is WAY TOO MUCH MONEY. In fact, It embarrases me when I have to price one for somebody. It is over a hundred and fifty bucks and easily worth less than 1/3 the aquisition price ::) If my tail light perverter (opps, converter) ever fails I'll replace it with a Hoppy or similar.
    D-
  13. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I ordered the Hoppy plug in. We will see if it fits.
  14. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    The Hoppy plugged right in 8) and it worked too!
  15. Brentbba
    Brentbba Former Golfer SILVER Star
    9,824
    321
    Mar 27, 2003
    OC, CA
    Kurt, that's good to hear!
