- Thread starter
- #21
up date:
still a bit slow for my style , but plenty of things to fix
here you can see a side view of the pop up roof , almost finished .
my objective is to have the maximum inside space usable .
normally we are traveling in 2 person .
with this hight I am amble to stand from the back of the front seats to the end of the car .
i am 180 cm high .
the hydraulic pistons that you see are not the final one .
as soon as they arrive most probably the will change direction .
the base is finished and the top almost .
we now have the roof rails for sand panels ecc.
just have to glue them up on monday .
on the glue side We have chosen Sika flex 252 .
that should perform well on vibration and on tensile strength ,
a test is ongoing from friday afternoon , we'll see on monday how the glue is performing on bare aluminium .
can't wait to see the test .
bed panel should be delivered on monday , we hope.
as well as othe bits and pieces .
here is what the front part looks like .
the front from inside looks a bit messy , but at the end will work out fine.
i tried to keep the level of the inside roof as high as possible , in order to fit a consol that was fit previously.
the 20 cm that you see is where the hinge of the bed will flex just on top of the console.
nest week I hope will final one for natal work .
then we should only have the outside tent .....i hope .
ciao Renago
i am 180 cm high .
ciao Renago
