TJM USA Builds some fun....In 3 Nights!
Here is a little tip.... Put your neck bolts in lose in the snorkel and get your bracket lined up and taped while..... Helps to have a extra set of hands to hold the snorkel in while this is done as we don't want to bolt it in just yet.... Just get the neck bracket sorted before you go bolting in the main snorkel..... Then mark and drill your holes. As this is right on the drip rail edge we used some silicone under the plastic inserts and bracket as good measure to keep rust at bay.....
Now find your best double jointed friend, grab his friend the contortionist and bolt in the snorkel...... No matter what the instructions say, your only going to get 3 of these bolts tight. The fourth is simply unreachable for our fat hands.
I'll say our front side bar mounting brackets around the catalytic converter is kinda tricky..... Takes a little thought from 3 heads to get it right. If any of you guys ever have to install these on your own, call us and we will give you some tricks to make things go smoother!!
:popcorn::popcorn:
