thought I'd be smart wrong answer
Discussion in '40- & 55-Series Tech' started by wayne_fj40, May 8, 2003.
  1. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes when was redoing the inside figured I'd take the hole saw mount new gauges up on the upper part of the dash.In the process found out It was harder than I thought but not bad when nothing else is there.Last night fired up the cruiser after mounting the dual exhaust started oil shot everywhere, inside at the new gauges and right buy where it goes into the block come to find out water temp gauge shorted melted the tubing in a couple of places.So pulled the cd player out of the dash and ashtray and speedo cluster out of the way and it still took and couple of hours to get the bastards out.Anyway long story short I'm starting to see why know one mounts gauges in the steel dash (but it looks good)go home tonight mount the new ones in same location or cut out dash and put stainless in :slap:
  2. Erics75
    Erics75
    81
    Jun 14, 2002
    That sucks, electric gauges are the way to go, no oil line. This is a little off subject but in 1999 we bought a brand new Chevy Tahoe on a Sunday and on Monday my wife drove it to work. I got a phone call, wife in histerics, the Tahoes oil pressure dropped, light came on, fortunatley my wife shut it off before any damage, but come to find out the oil cooler line popped off inside the engine bay, oil was everywhere on the brand new engine. In was pissssed offffff. Anyway the dealer spent hours detailing it and all is good but I know the feeling.
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes I think you're right I should lok into electric gauges Its not full proof but less chance of it happening there again witch would be good :G
  4. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I personally don't trust electric gauges.....have never used them, and never had a problem with the mechanicals. For the oil gauge, definitely toss the plastic tubing and go with copper for longevity.
  5. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    That is true I got to thinking after earlier(scary thought thinking)but my old 70 chev pickup and 76 chev pickup come with factory mech. gauges with copper tubing so I may look into this :G
  6. cruzer
    cruzer
    586
    1
    Oct 18, 2002
    copper is the way to go...carquest or napa has everything you will need most likelyt...holds up much better
    Stew
  7. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    I have to switch to copper this weekend. I had a pair of rather exciting fires while pressure testing my FI. There seemed to be problems afterwards, but I had no oil pressure. The plastic hose had melted in half, but had cauterized itself so it didn't leak.
  8. ranger
    ranger
    1,153
    2
    Jan 18, 2003
    Mountain Hole, Idaho
    Mechanical gauges are by far the best...I have never had any issues with mounting gauges on the dash. Just have to make sure you use grommets. Idf you are installing the plastic oil line, the trick is to put the ferral on straight and don't over tighten the nut. Otherwise the ferral will cut into the plastic line, and cause a leak.
