Switching Oil Viscosity
Discussion in '80-Series Tech' started by Imagery, Sep 9, 2003.
  1. Imagery
    Imagery
    343
    1
    Aug 26, 2003
    Beaumont, Texas
    I would like to switch to Mobil 1 whatever weight may be suggested in the previous posts on the topic... I will look over them to make sure but I think someone said it is best to use something like 5w-40 in Mobil 1. A friend said that he heard it was bad to change viscosities once a motor is used to running a certain weight. Is this true??
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Cary can probably speek to that best but I'll take a stab. I think not because the owners manuals publish viscosity ranges for usage based on ambient temperature and make no mention of using only one weight.
    Dan.
  3. cary
    cary
    3,109
    21
    May 7, 2003
    It is an old wives tale. For years people would run 20w-50 in the summer and 10w-30 or 10w-40 in the winter. Just use the Mobil 1 0w-40 year around. If you have consumption issues then go and search out Mobil Delvac 5w-40 at a truckstop.
    Cary
  4. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Cary,
    What's the wives' tale, staying with one weight "because the motor is used to it" or changing weights for significant temperature changes? (pre-synthetic, of course).
    D-
  5. cary
    cary
    3,109
    21
    May 7, 2003
    The old Wives tale is changing weights will harm the motor because "it gets used to it." These are the same guys that don't understand that from -10F to 200F 10w-30 changes thickness by a factor of 300 (Goes from about 10 Centastokes at 200 F (operating temp) to 3000 centastockes at -10F).
    Also don't forget that a 10w-30 synthetic is no thinner than a 10w-30 mineral at the -25C low temp test . If the synthetic was thinner it would be called 5w-30. That said at very low temps (i.e. -50c) the synthetic 10w-30 may continue to flow while the mineral will not, but it is so thick as to be not pumpable anyways.
    Mobil 1 0w-40 is the way to go because it is the same thickness at -40C as 10w-30 is at -25C. On the other end, the 0w-40 is about 40% thicker than the 10w-30 at operating temperature.
    Cary
  6. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    [quote author=cary link=board=2;threadid=5122;start=msg39578#msg39578 date=1063156208]
    [/quote]
    Why does the Delvac help consumption?
  7. cary
    cary
    3,109
    21
    May 7, 2003
    Delvac 1 is slightly thicker than M1 0w-40, both at starting and operating temperatures. It seems to help consumption a bit. Also, sometimes some cars just don't agree with certain oils, if you have a car that consumes 1 quart every 1000 miles on one oil another brand in a differnent weight may drop the consumption in half. I have not had any trouble with consumption with the 0w-40, so far having burned 1/4 quart in 2000 miles.
    Cary
  8. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    Cary, what are your thoughts on straight 30 weight oil? And is there such as 30-40 or 20-40 (not 20-50) for extraordinarily hot climates/conditions? You've talked about combining different weights from the same brand...
  9. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Mercury Marine has a 25w40 oil for I/O engines. I run that in my 4.3 GM powered Chaparral. They claim it is for severe service. I guess 4800 rpm WOT runs constitute severe service.
  10. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    I've always wondered about using an ashless dispersant 40 weight aircraft oil. I'm always interested in the quality of aircraft parts and just read this the other day:
  11. cary
    cary
    3,109
    21
    May 7, 2003
    Here are my thoughts:
    1) Straight weight oil- Don't waste your time. There is no advantage.
    2) 20w-40- Not any thicker than 0w-40, 5w-40, 10w-40. For extrodinarly hot climates you would step up to a xw-50 oil (there shouldn't be a need though). The reason that you don't see 20w-40 anymore is that the other multi viscosity oils take its place. So why did it ever exist? Because back in the dark ages of multiviscosity oils, the viscosity modifiers and pour point depressants needed to make a mineral oil multiweight would break down quickly and cause sludge. The wider the oils weight span the more modifiers needed the more sludge created. In the past 30 years the base stocks for mineral oil and the viscosity modifiers and pour point depresants have improved considerably. Today there is really no problem with sludging from viscosity modifiers and pour point depresants. They still break down, but much slower and without the crud left behind. Synthetics tend to need less of these additives and it is widely speculated that Mobil 1 10w-30 does not in fact have any viscosity modifiers or pour point depresants (note this is different than detergent)
    3) Aircraft Oil- This is completely different than auto and truck oil, just like aviation gas is different than pump gas. DO NOT MIX CAR STUFF AND AIRCRAFT STUFF, IT IS A RECIPE FOR DISASTER. Just a few items, aircraft use leaded gas and no cat converters, no 02 sensor, and have entirely different service conditions and intervals. The oil for aircraft would likely destoy the emisions system in an automobile because of the different additive packages. In fact the change from API grade SJ to SL was not to improve the lube qualities but to lower additives that damage emissions equiptment.
    Also the guy who is being quoted about synthetic being to slippery doesn't know his ass from a hole in the ground.
    Cary
  12. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Cary,
    My, my, wouldn't it have been nicer to say that he couldn't find his bottom with both hands and a flashlight at high noon? ::)
  13. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    [quote author=cary link=board=2;threadid=5122;start=msg39938#msg39938 date=1063225503]
    [/quote]
    I have to remember this is an 80/100 series area, but my question pertained to F/2F completely desmogged engines BTW.
    I just looked it up on google a while ago and deleted the URL when posted. Wonder why Mobil AV1(or whatever their aviation oil was) didn't make it then?
  14. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    Warm engine, Drain penzoil 10w30 oil, remove filter and replace with new filter, replace with new mobile 1 oil. :D :D :D :D :banana:
    Cheers
    Sean
    "I could not help myself" :D :D :D
  15. Imagery
    Imagery
    343
    1
    Aug 26, 2003
    Beaumont, Texas
    [quote author=MTNRAT link=board=2;threadid=5122;start=msg39958#msg39958 date=1063228165]
    Cheers
    Sean
    [/quote]
    Thanks guys... This has ben very educational and I believe I have a good understanding about different types of oil and viscosities. I am going to drain the Penzoil this weekend, get a case of Toyota filters from the dealer, and go back with the M1 0W-40. Thanks for the great advice.
    Mark
  16. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,002
    60
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    SAE 20W/40 is a very common Oil(Especially for Mixed Fleets), Such as on a Farm. - Penrite Universal Farm. :flipoff2:
    How about for an Engine that operates in a consistant Enviroment, Where the Temperature and R.P.M. is constant. :flipoff2:
  17. cary
    cary
    3,109
    21
    May 7, 2003
    [quote author=Jonathan_Ferguson link=board=2;threadid=5122;start=msg40121#msg40121 date=1063250890]
    :flipoff2:How about for an Engine that operates in a consistant Enviroment, Where the Temperature and R.P.M. is constant. :flipoff2:
    [/quote]
    That is true, but I don't think that automobile motors qualify for that. Oh, I should mention that since you are down under, you should be using 40-w0 because everything is backwards. :flipoff2: :flipoff2: :flipoff2: :D :D :D
    Couldn't help myself.
    Cary
  18. cary
    cary
    3,109
    21
    May 7, 2003
  19. Jonathan_Ferguson
    1,002
    60
    Jul 2, 2003
  20. lovetoski
    lovetoski SILVER Star
    4,421
    119
    Jul 13, 2003
    Question on Delvac for Cary
    Cary,
    If I understand, Delvac is a type of Mobile 1? (I went to the "Delvac" page on Mobils' website - but I'm not a chemical engineer!).
    In a higher milage cruiser engine, well maintained, but with higher oil consumption (1 qt per 300-500 miles, but strong compression) would Delvac be advised or not?
    Thanks for your advice,
    Doug Graham
