Suspension kit recommendations (BJ-60) OME, ?
Discussion in '40- & 55-Series Tech' started by Traveler, May 5, 2003.
  1. Traveler
    Traveler
    2
    May 5, 2003
    I'm going to be replacing the suspension on my BJ-60 soon and would like to get some 1st hand recommendations on which manufacturer to go with. I have heard many good things about OME.... if I were to get their kit which one would be the best for combined street /off-road use.
    Any ideas on the best place (cheapest!) to buy it from?
    Thanks
  2. erfworm
    erfworm
    348
    30
    Apr 10, 2003
    Are you looking for lift or stock height?
  3. Guest
    Guest Guest
    OME on my BJ40 is far too soft. Any way the Springs are made by King Springs in Sydney and the Dampers are made in Adelaide by Monroe.
  4. jzilla
    jzilla
    1,633
    44
    Feb 26, 2003
    Edmonton, Alberta (for now...)
    wRe: Suspension kit recommendations (BJ-60) OME, ?
    I have belton suspension on my bj60 I think it is a 2.5 inch lift.
    It fits 33's easily.
    It was reasonable and I'm told comparable to ome, with ome I think you are paying some extra for the name.
    The belton kit came with everything shackles, bushings, shocks, steering stabilizer.
    I have had it on since august and I'm quite happy.
    Seems pretty heavy duty. It is a bit bouncy.
    Let me know if you need more info.
  5. Traveler
    Traveler
    2
    May 5, 2003
    erfworm: I'm looking to get 2.5" of lift, that should be plenty.
    jonathon: Which OME do you have, the light, med or heavy?
    jzilla: Thanks, I'll check out belton, where did you get yours?
    Thanks guys
  6. erfworm
    erfworm
    348
    30
    Apr 10, 2003
    I've got the medium OME 2.5" suspension on my 62 and it works great. However, I think that once I add the bullbar and winch the medium will probably sag considerably in the front. If you've got the diesel and a lot off weight upfront I think you might want to go with the heavy. Unfortunaely I don't know how the heavy will ride, but I can tell you that with the medium my on road characteristics actually improved greatly over the stock set-up. :G
  7. Guest
    Guest Guest
    I have the 2.5" Heavy Duty. Also the front has sagged heeps, But a lot more on the right side. Rear is about right, Just soft.
  8. Guest
    Guest Guest
    Forgot to mention: The Dampers are Valved too hard(Damper slows the Spring too much).
  9. jzilla
    jzilla
    1,633
    44
    Feb 26, 2003
    I got mine through a guy in coqutilam B.C.
    His name is Steve.  He has a website called extreme bends.
    his number is 604 834-Fj40.
