Steering Knuckle Bearings...
Discussion in '40- & 55-Series Tech' started by del3030, Jun 22, 2003.
  1. del3030
    del3030
    30
    Feb 26, 2003
    Does anyone know a good place to get a cheap front axle rebuild kit? I have a 78 FJ40 and one of the knuckle bearings is shot. It's a KOYO Part #303030. Someone suggested I try a Knuckle bearing from an 85 4Runner Solid front, but it did not fit. It was some German bearing, part #30303 ... but no extra 0. Anyway, it would not fit... I am so tired of looking at my truck on jackstands. I wish this 3 month SOA project would be over soon so I can actually drive this thing once in a while. Someone please help. I think it would be wiser to just go ahead and replace all the bearings and seals up there now while I have it all apart.
  2. Pin_Head
    Pin_Head
    13,752
    1,321
    Feb 6, 2002
    OC, CA
    The correct bearing is 30303 D. A regular 30303 will fit, but it has a different taper and will not last as long in this application.
  3. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    The cheapest quality kit is at Heart Of Texas Off Road http://www.heartoftexasoffroad.com/.  Robert stocks kits with Koyo bearings.  Good idea redoing the seals while you're at it. $78
    Are you referring to Timken bearings?  US made AFAIK.  Did you change the bearing race too?
    Dave
  4. tuolumnejim
    tuolumnejim
    228
    Jun 24, 2003
    Tuolumne, Ca.
    I got mine from jt outfitters all the bearings,seals,gaskets and shims 99.00
