Squeaky Fan Belt
Discussion in '80-Series Tech' started by Jim_Phillips, Jul 3, 2003.
  1. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    My fan belt has started squeaking. Does it need lubricating or drying? I've got talc and WD40 to hand - is either one worth a try?
    Cheers, Jim
    Hey Junk - I put 'Junk' into Google and came up with this guy - is this you? :D [​IMG]
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,567
    2,896
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Jim,
    If it is a belt, I would replace it. Did this start up after your over-rev?
    Dan
  3. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    It started just now. I did spill a little oil on it whilst 'topping up' - maybe this is the cause of the problem?
  4. cruiserdan
    20,567
    2,896
    Mar 27, 2003
    Maybe. In any case I would not put an oil of any kind on a belt(including WD40) on purpose. An old trick that works short term is bar soap rubbed on the sides of the belt. DO NOT attempt this with the engine running or it will be difficult for you to post the results :eek: .
  5. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    Thanks Dan, I'll give that a go.
  6. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    Fantastic - that did the job. I'll keep an eye on it for a while..
    Cheers, Jim
  7. sjcruiser
    sjcruiser
    834
    2
    Apr 3, 2003
    Dan,
    I had thought that my belts were squeaking; turns out it's the alternator bearing that was the cause (spraying Silicon quiets it for a few days). &nbsp:Do I have a simple (permanent) fix for this, like swaping out the bearing?
    Frank.
  8. cruiserdan
    20,567
    2,896
    Mar 27, 2003
    Frank,
    Are you spraying into the alternator nose piece or are you refering to the idler below the alternator that rides on the inside of the alternator belts?.
  9. scottm
    scottm
    3,140
    Media:
    8
    870
    Mar 27, 2003
    Third Coast, USA
    Drizzle soapy water on the fan belt to remove oil, watch out for spray. Belt dressing helps keep it soft, available at most hardware stores and some auto stores.
  10. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    LOL. No. That's the guy that beat me to your momma's place during her last 1/2 off sale. :eek: :D :D :D :D
    Geez, you give a guy back his cruiser and he gets all feisty. :D :flipoff2: :D
  11. sjcruiser
    sjcruiser
    834
    2
    Apr 3, 2003
    Dan,
    I was referring to the nose piece - spraying Silicon directly to the center of this bearing suppresses the noise completely.
    Frank.
  12. cruiserdan
    20,567
    2,896
    Mar 27, 2003
    OK Frank,
    Yes you can get just a front bearing. As I am not at work at the moment I can't be specific but it is probablly 20 bucks or less(+beers to do it). I am working tomorrow(7-5) as the dog is hungry. I will confirm the info and post back.
    Dan.
