spark plug removal
Discussion in '40- & 55-Series Tech' started by bad_religion_au, May 29, 2003.
  1. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    tried pulling my spark plugs today (for 1st time on new rig) and they wouldn't budge an inch, any tips? i'm too scared of breaking them off, so any little tips, it's a 2F if that really matters
  2. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Get some PB Blaster and soak down those puppies. Wait an hour or two, and give it another shot. I wouldn't use any air tool, just either a good long torque wrench or regular ratchet with breaker bar, I find on stuck nuts and bolts impacts and air ratchets make the problem worse by snapping off heads of bolts and breaking the bolts nuts are on. Then again my mechanic used an impact to remove my sparkplugs right after I bought the cruiser (same day,) cause he was closer to where i bought it than I am, and he didn't have any problems, but he's more skilled than I am. :dunno:
  3. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Also,
    Do it when the engine is at operating temp...every little bit of heat helps.
  4. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    wd-40
    any excess that enters the piston will easy burn or be blown out in the first compressions.
  5. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Thats the only thing I'm worried about, I don't know if PB blaster is flammable or not, and I don't think it would do anything to the rings or anything like that, but wd-40 or cheap oil based spray lube might be better than the specialty penetrating oils like PB and Liquid Wrench for that reason.
  6. Pete112
    Pete112
    19
    Nov 15, 2002
    PB Blaster will definetely burn off even if not as well as WD-40. Also, make sure you use a 6 point socket rather than the 12. Last thing you want to do is put all kinds of torque into getting it off only to end up with a round spark plug. That will make it really tough!
  7. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Oh yeah, go get an actual spark plug 6 pointer-they are the perfect depth, 6 points, and have the rubber deal inside so that you are less likely to accidently try to take it at an angle and break the sucker up.
  8. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    PB Blaster over WD-40 any time when you have to loosen something. WD is a fine light lube or water dispersant, and sure is better than no penitrating oil, but, as stated before on this list, PB Blaster is the Shiznit.
  9. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Wonder who said that? :D
    Words to live by....
  10. Jman
    Jman
    1,548
    172
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    And when you put the new ones in, put a little antiseize on the threads--you don't have to go nuts, just a little will help when you need to pull them again.
    Actually, an old hot rodder told me he used to put cherry Maalox on them (cheaper and less messy than antiseize). Anyone else hear that one?
  11. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    Never use a torque wrench for breaking things loose!!!...:)They're for tightening...use a breaker bar or long handled ratchet for loosening...six point sockets are a fine idea...
  12. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Why not? I like using the torque wrench cause its about a foot longer than my 1/2" drive ratchet, and I don't have a breaker bar. I just crank it up to its highest setting and wrench away. Oops, guess I shouldn't have used it to break loose every single bolt on the entire suspension that the impact didn't take off... :stupid:  I guess it hurts the innards of it or something?
  13. archie
    archie
    1,183
    3
    Dec 14, 2002
    NW side of chicago
    I agree with everybody but with the added advice of blowing out any debris with compressed air from the socket area before spraying any lubricant. This ensures no foreign material entering the engine(ex. sand and mud like substance that will clump together when lubricated). slip over an ever increasing longer pipe over your rachet wrench and push slowly till loose. I thought that my 62 plugs were on so tight that they were threaded the opposite direction. Good luck.
