Had a key cut at Lowe's for the Seqouia and tried to use it today. Strangest thing I've seen happened. The engine would turn over but would not start, and would continue turning over until you flipped the key back to the off position. Basically you would flick it once to the start position and it would continually turn over in the on/acc. position.
Why would the key I had made not start it? Is there a chip? More puzzling - why was the starter stuck open?
Started normally when I used the factory keys.
