rear fender cutting
Discussion in '40- & 55-Series Tech' started by matgood, Mar 11, 2003.
  1. matgood
    matgood
    15
    May 15, 2002
    What is the best way to cut the rear fenders for better tire clearence?
  2. rustycruiser
    rustycruiser
    158
    21
    Feb 25, 2002
    Maryland
    Plasma, jigsaw, sawzall, cutting wheel all get the job done.
    Or perhaps I don't understand your question?
  3. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Plasma ALL THE WAY.....ahhh the feeling of cutting metal like a hot knife through butter
  4. cruzer
    cruzer
    586
    1
    Oct 18, 2002
    Use masking tape to tape over the area you want to cut out. Then trace the line out on the tape. Then use whatever means you want to cut the rear fenders.
    Stew
  5. Guest
    Guest Guest
    When you do cut the fender, what's the best way to keep the new cut and the rivets holes(from the flare) from rusting?
  6. matgood
    matgood
    15
    May 15, 2002
    Sorry, I wasn't all that specific when I typed in the question... Was really tired when I wrote.. What I meant was how far does everybody go up when they cut there fender? 1", 2"... And so on.. I am planning on putting some fender flares on would it be wise to wait for those?
    Thanks in advance
  7. Lane
    Lane
    8
    Feb 1, 2002
    8)Wait for the flares, then use them as a template. Remember that there is a big (thick) piece of steel at the front of the wheel well that you don't really want to cut through.
    Lane
  8. nuclearlemon
    nuclearlemon not an addict Moderator
    15,585
    Media:
    87
    404
    Jan 30, 2003
    meh-ico, colorado
    paint the cut, and dip the rivets in clear silicone before installing.
  9. nuclearlemon
    15,585
    Media:
    87
    404
    Jan 30, 2003
    meh-ico, colorado
    are you running flares...if so, do like it says above and use the flares for a template, if not, use a piece of cardboard...hold it over the opening and trace from behind. cut in half and use the two angled edges to get the angles on the bends right. i usually cut to about 1/2" under the fender top
