Rear disc brakes
Discussion in '40- & 55-Series Tech' started by 79fj40, Apr 24, 2003.
  1. 79fj40
    79fj40
    380
    Apr 6, 2003
    Sumner, WA
    I am going to do a disc brake conversion on my 79 fj40, I would like some input on what you guy's have used and recommend. I have looked at TSM and JT Outfitters system's but I would like to know who is happy with what they have got. Thanks for any info. :beer:
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I used Cardinal Fang brackets (no longer available, but the diagrams are in the tech section) with machined chevy rotors and monte carlo calipers. Add in a Summit proportioning valve and it would be very streetable, but it works fine on road now and great offroad.
    IMO, the purchased kits are bucko bucks for what outta be a $250 project.
  3. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    Yeah, search the tech links here and gather a parts list. Go to a junk yard or auto parts store and get all the parts you need. Get the rotors machined to fit the rear axle and put it all together. Save yourself some money and gather the parts yourself. Good luck!
  4. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    I did just what woody did, and yeah, it was about $250...
  5. MarkFJ40
    MarkFJ40
    73
    Apr 18, 2003
    One of the best upgrades I've done.
    You'll love disc brakes.
    Take the drawing off the tech section to a place that does water cutting and get them to make the brackets for you.  Even if you just buy the brackets somewhere and source all the other parts it'll cost you a fraction of any of the "kits" available.
  6. 79fj40
    79fj40
    380
    Apr 6, 2003
    Sumner, WA
    Thanks for the info. Sounds like you guys just saved me some money. One more question. Are the brackets that you can buy through JT good enough to use or should I have some one make them using the templet posted in the tech section? Thanks again :banana:
  7. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    IIRC, JT simply "duped" the Cardinal Fang bracket....and also IIRC, there might be some "bad blood" mixed into that as well....
    so yes, the JT is an exact duplicate....
  8. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Another source for the brackets only is Dave Custer in Bend, OR. Like the others mentioned, these are laser cut from 3/8" steel based on the template on the Tech Section. You can reach Dave at alchemymetal@earthlink.net.
  9. Straylight
    Straylight
    87
    Feb 24, 2003
    can I do the same thing for my fronts? switch them from drums to disks just by getting the brackets and out-sourcing the calipers, pads, etc?
    Straylight.
  10. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    Now front disc brakes
    You can get later model land cruiser knuckles, and swap the knuckles on out onto your drum brakes, as long as they are birfiels, and not the eaaarly cup and ball joint. Minitruck knuckles and fj60 knuckles will work as well, and get you a bigger, stronger birfield and steering arm bolt pattern...
