Re-installing Battery - Sparks, Smoke Help
Discussion in '80-Series Tech' started by skii, Mar 21, 2010.
  1. skii
    skii
    90
    Jan 5, 2010
    Vermont
    Removed the battery and box this morning to work on a belt issue. I reinstall the box, ground wire, holding bar and battery. Hook up the + first and then hooking up the negative I get a spark, the lights go on and I sometimes get a bit of smoke. This can't be good, whats going on?
  2. lt1fire
    lt1fire
    15,240
    Media:
    6
    1,074
    Oct 4, 2006
    Seattle, WA
    When there is smoke normally it means that the positive and negative are bridging somehow. Check those connections again.
  3. Ivan80
    Ivan80
    341
    Media:
    4
    1
    Mar 28, 2006
    Omaha, NE.
    Assuming you have the battery polarity correct and you didn't create some sort of short when wrenching...If you have accessories on, like lights as you mentioned, it is normal to get a spark at the battery terminal when hooking up the battery. I imagine the smoke you speak of is from the spark?
    Turn off all the lights, remove the key from ignition, shut the door (so the door courtesy lights are not on) if you want absolutely no spark, pull the radio and the dash clock fuse and reconnect the battery.
    If you still get anything other than a very minor spark, you have created a short somewhere.
  4. skii
    skii
    90
    Jan 5, 2010
    Vermont
    I turned off the lights and after a brief spark all was well. First time I've done this so I was concerned.
  5. SBFJ60FIG
    SBFJ60FIG
    1,015
    3
    Jan 12, 2006
    Chicago!
    Yeah no worries, a little spark will happen...when I re-hook up battery cables I do it quickly as I know there will be a small spark. And not that this really matters but at times I will blow on the area prior to hooking the cable up to clear any potentially explosive gases that may build up.
    This last part is probably totally not needed as I've hooked up many many batteries in my years of car, boat, etc repairs and I've never had a problem. But they do put blowers in boat engine compartments for a reason right?
  6. tlcruiser66
    tlcruiser66
    713
    Sep 4, 2006
    Western Wa.
    Sparks aren't normal unless you have a draw on the system, if your accessories were all off you may want to look into where that draw is coming from or you may find yourself stuck someday because of a dead battery.
  7. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    I just replaced my HG and am having a similar problem. I connect the + battery cable first and then connected the negative side, the horn went off and there was spark, smoke, crackling, etc on the negative terminal. I quickly disconnected the negative and did some troubleshooting. I found that when the GREEN wire is connected to the + terminal, the terminal sparks and smokes when I connect the negative side. If I don't connect the green wire, there's no issue when connecting the negative. Without the GREEN wire connected to the + on the battery I tired to start the truck but I'm not getting spark. The coil was checked per FSM and is working fine. I'm getting power into the coil but nothing is coming out. I'm stuck and have no idea what could be wrong. I checked all of the connections and grounds and everything is in place. I do have a KARR alarm that was on the vehcile but am not sure if this might be causing the issue with the horn. Any help or troubleshhoting ideas would be greatly appreciated. The LC has been down since December and I'm so close to getting it back on the road.
  8. atomicshawn
    atomicshawn
    913
    Media:
    26
    510
    Aug 18, 2010
    the west desert
    I’m thinking you’re on the right track with the car alarm. I have soiled myself on many occasions because of those d*#mn alarms going off when connecting the battery… as if you’re not nervous enough after doing a big engine repair like a hg. Does the “green wire” your referring to look like part of the factory harness, or is it isolated? How does it attache to the battery. Pictures would help.
  9. B Legit
    B Legit
    478
    3
    Mar 21, 2010
    Seattle
    a pretty common law in the electrical world is that your ground should be "First to make and last to break". I would also completely avoid making and breaking connections when there is any kind of draw on that system, that should be the only reason you see sparks unless you are shorted to ground somewhere in your system.
  10. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    The harness looks factory to me. The alarm is not Toyota so I'm unsure how it's linked to the wiring harness. Attached are some pics. The GREEN wire also broke and was replaced. (all wires were replaced)
  11. Dave 2000
    Dave 2000 Not all Land Rovers are useless! SILVER Star
    2,288
    274
    Jan 24, 2009
    Spain
    Well a couple of things come to mind:
    Yes the alarm can cause the battery terminal to spark along with the central locking taking up it's lock/unlock position, even many ECU's need to 'power up' at connection.
    Next with the 'first to make and last to break' saying, I have used that saying before but have found the following:
    The battery connection will still spark regardless of which is connected first if there is a current draw, I often put the earth on last, many batteries have the positive nearest the wing or fender if you will, if the earth has been made first then it is possible for the spanner you are using to tighten the positive terminal to short against the now earthed bodywork and can blow a hole in it, at the very least you will have a ton of sparks and if the battery has just come off charge then it will be venting explosive gases and the results can be horrific.
    Connecting the other way around is a lot safer and if you touch the bodywork/engine metalwork no big deal assuming of course you do not short the battery terminals together or your car has a very old positive earth system. :whoops:
    regards
    Dave
  12. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    I forgot to mention that when I checked the fuses under the dash, the CIG 15A, WIPER 20A, GUAGE 10A, AND ECU-IG 15A were all blown. I'm going to check all the connections on the wiring harness to verify that it was done correctly.
  13. atomicshawn
    atomicshawn
    913
    Media:
    26
    510
    Aug 18, 2010
    the west desert
    That "wire" is actually a fusable link which is designed to break if there is a short, but they can be fragile and can break from physical stress. I was hoping it was an add-on circuit, that would have made this much simpler.
    So that circuit is powers a lot of stuff; pretty much everything related to the MFI system and some lighting, so yeah, if that is disconnected it wont start. You were moving a lot of those circuits around when you had the head off, so there is a chance you got something pinched or chaffed.
  14. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    I'll go thought the whole car and see what I find. I'll keep this updated. Thanks atomic for the info.
  15. skibob
    skibob
    136
    1
    Oct 15, 2010
    Oregon City
    firs to break last to make is ABSOLUTELY BACKWARD when working with your car battery.
    Think of it this way, if you connect the pos after the neg, and your wrench touches a grounded metal part, you will get more than a little spark. If you really ground out, you can discharge the entire contents of your battery. That's a lot of juice. Your wrench may become very hot, may even weld to the body. You can end up with burns, the battery can explode under just the right/wrong conditions.
    Conversely, if you connect the positive first, then the neg terminal, you can touch whatever you want as many times as you want, since there is not a complete circuit, the worst that can happen is that you will scrape your knuckles.
    cuencanolenny likes this.
  16. Dave 2000
    2,288
    274
    Jan 24, 2009
    Spain
    Come on skibob have you been skimming the posts again?
    Check out post #11, you could have saved yourself some ;) typing
    regards
    Dave
  17. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
  18. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    I rechecked all of the connections and wiring. Off to Toyota it goes.
  19. atomicshawn
    atomicshawn
    913
    Media:
    26
    510
    Aug 18, 2010
    the west desert
    If you have to take it in, the dealer is often your best bet, but spendy. Too bad your not in northern Utah. Let us know what they find. I'm interested.
  20. enterconnect
    enterconnect
    530
    Media:
    21
    7
    May 6, 2009
    AZ
    I'll post the outcome.
