Getting ready to ditch the LSPV in place for a manual proportioning valve up near the master cylinder in the engine bay. I plan to reuse what I can from the stock lines and fittings but I'm a little confused about the types of flare nuts used.
From my research, it appears we have brake lines with a 4.75mm OD, M10x1.0 thread on the flare nuts and a double bubble flare on the ends.
That's great and all, but the ABS actuator has a different type of flare fitting. Another member said this fitting will leak if used in anything aside from the ABS actuator.
Here's the pic, brake line fittings on the left, actuator fitting on the right. Does this fitting on the right have a name? I'm trying to figure out what I need to cut and re-flare in order to install a manual Wilwood valve on the REAR-OUT line of the actuator.
If I can't use these fittings in anything else it will be a lot more cutting and flaring of lines that are attached in the engine bay....and I'm not even sure how I'd do that without a vise!
Mock-up of the Wilwood 260-12627 valve
